Dimmer lights broken for Circulation/AC buttons
Old Nov 26, 2012
ishaan7's Avatar
ishaan7 is an unknown quantity at this point
I have an '03 Civic LX Coupe.
The buttons that control the interior circulation and A/C don't "glow" anymore, unlike the rest of the instrument panel, irrespective of dimmer setting. Note that this is different than the indicator light that tells you if that feature is enabled or not.
I've also seen, on occasion upon starting up, that the fan speed indicator doesn't "glow" either. However, it starts glowing normally after some time.
Has anyone experienced this?
Thanks!
Old Nov 26, 2012
CraigW's Avatar
Re: Dimmer lights broken for Circulation/AC buttons
The entire audio/hvac pod uses 5 individual neo-wedge bulbs for illumination.
Order all 5, and change them all at once.
Old Nov 26, 2012
The three dials share 2 bulbs and the three buttons share 2 bulbs, as well, to illuminate the "lettering" and whatnot on them, if I'm not mistaken. The indicator lights for each button has their own LED associated with them. Those 3 LEDs are soldered to the board, itself.
To fix your problem, you (presumably) need to buy #12 on the drawing, two of them, to be exact.
List price for them is $3.35 each, or $2.35 (plus shipping) if you buy them from Majestic Honda.
http://www.hondaautomotiveparts.com/...HEATER+CONTROL
Old Dec 28, 2012
Vexorg's Avatar
Vexorg is an unknown quantity at this point
You need to take the console out to remove the lights right?
Old Dec 29, 2012
CraigW's Avatar
You have to take the 12 volt outlet panel out to remove 2 screws behind it... then you pop out the audio/hvac pod.
Old Dec 29, 2012
Vexorg's Avatar
Cool thanks
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
stryder12
Jun 30, 2015 08:33 PM
Blazz
May 25, 2015 10:56 PM
civic_gt
Apr 19, 2015 08:15 AM
SSMatey
Apr 13, 2015 06:09 PM
