DIY: Cruise Control FIX w/ LED tail/brake lights
Old Mar 13, 2009
  #61
Re: DIY: Cruise Control FIX w/ LED tail/brake lights
but only for coupes
Old May 1, 2009
  #62
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
riceboi I NEED A LINK to those. ME LIKEY
Old May 6, 2009
  #63
fixed the pics
Old May 6, 2009
  #64
fiend's Avatar
fiend is an unknown quantity at this point
as stock and as led as you can get!
where did you get those at and do they make them for the 01-03 models?
Old May 6, 2009
  #65
its just ebay led tails. fits 01-05 civic coupe but you may need some new sockets or rewiring for 01-03.
Old May 6, 2009
  #66
fiend's Avatar
i thought that. i figured if i was to get those i would have to wire them up like people do when they put 04-05 tails in there 01-03
Old May 6, 2009
  #67
sl33pyriceboi's Avatar
there on ebay. but they were made for the 04/05. so ur gonna needa do a 04/05 conversion. (basically just buy the turn signal sockets from the 04/05)
Old May 6, 2009
  #68
DieMaster's Avatar
thanks gearbox for fixing the pics.
UPDATE. i recomend a 100K resistor not 10K too much current goes thought it with the brakes on and can burn out the resistor.
Old May 7, 2009
  #69
at least you would know if it burns out tho right cause the cruise will stop working again
Old Jul 23, 2010
  #70
Nosepicker's Avatar
Nosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the rough
Question: My CC is still not working and I can't get it to work. Cruise button light stay on when pressed but try to set the speed it doesn't hold the speed at all.
Checked the CC wiring/cables and everything looks good.
I have stock bulbs.
Would this mod fix my CC even though I'm running stock? What is this 4th light mod you guys or rather that other guy talking about? Easier the fix the better.
I drive a '98 LX.
Old Oct 10, 2010
  #71
Scouter2P's Avatar
Scouter2P is an unknown quantity at this point
I know this thread is way old, but I just did this with my car. The CC box really is a pain in the ***, but I discovered that by lightly taping in a razor blade all around the edge, it makes opening the box a whole lot easier, took me less than 5 minutes to do it and didn't damage the box at all.
Old Oct 10, 2010
  #72
No worries. Things like this where you found a faster/easier/better/more efficient way to to a DIY are always welcome for bumping old threads.
Old Aug 3, 2011
  #73
MarkoPollo's Avatar
MarkoPollo is an unknown quantity at this point
UPDATE! i've found out 10K is a bit low for the voltage. this can result (as it did with me) as the resister turning to charchool. if u have a auto and have to hold the brakes down or do it anyway, i recomend 100K. (brown - black - yellow)
100K sounds good. But what is the wattage? 1/4W? 1/2W? 1W? 2W?
Old Aug 3, 2011
  #74
DieMaster's Avatar
i would go no less than 1/2 watt. simply because it's a direct conect between brake 12v and gnd when brakes applied. it's esentaly a heater when it's on.
Old Aug 27, 2011
  #75
MarkoPollo's Avatar
So is 1W better?
I know NOTHING about resistance.
The only resistance I know is when I'm trying to bust a move and the chickie isn't into it. Yeah, it's like I'm the persister and she's the resister.
Old Aug 28, 2011
  #76
the wattage does not affect the resistor's actual ohm value. all it does is tell you how well the resistor can dissipate heat without frying itself. when using the same resistance ohm value, its usually wiser to pick the higher watt version. they will get thicker and bigger as you go up, so eventually size becomes an issue. and for many things like 5mm leds, a 1/2w is more than you will ever need. if you are making leds for a closed area, then it would be better to use the higher watt resistors so they can handle the extra heat buildup.
Old Jul 21, 2012
  #77
ericf1993's Avatar
ericf1993 is an unknown quantity at this point
sorry to revive this thread again but im having trouble taking the cruise control box apart. ive tried using the razor blade and it still doesnt look close to opening. is there some sort of glue holding it together?
Old Jan 30, 2014
  #78
killaclownne's Avatar
killaclownne is an unknown quantity at this point
Hi gearbox:
I did this mod but I ended up getting 100k 1/8 watt resistor. I did not realize until now that you said 1/2 watt. But I did find out that if you use an 1/8 watt resistor it does not work. It is the same no cruise control. Put a third brake light filament bulb in and cruise worked again. So I am assuming the 1/8 watt ones won't work.......
Thanks
Old May 22, 2014
  #79
scorpionsinz's Avatar
scorpionsinz is an unknown quantity at this point
Does this fix also fix the issue the LED lights create with the automatic trans? The trans simulates a slipping trans when LED lights are installed. From what i understand, the lights mess up the voltage reading for the kickdown to first gear. I re-installed the oem lights until that issue is solved too. Ill give this a shot and see how it affects the trans kickdown. I'll update afterwards unless someone has the answer already.
Old Sep 10, 2017
  #80
tristanlee85's Avatar
tristanlee85 is an unknown quantity at this point
I'm a few years too late, but I just did the LED tail lights and experienced this issue as well. Obviously cruise control no longer functioned, but also taking off from a stop simulated slipping in 1st gear (auto trans) and while sitting in park without the foot on the brake pedal, you could constantly hear the locking mechanism in the shift selector clicking because it wasn't sure if your foot was on the pedal or not. This would allow you to shift out of park without depressing the pedal.
I did not do this mod since I was not sure if it would fix the other 2 issues unrelated to cruise. I ended up installing the load resistors at the bulbs and mounting them to the frame for heat dissipation. I would have liked to tried this mod to see if it fixed the other issues too, but was in a time crunch to get the car acting normal again for a long drive so load resistors was the quickest solution.
Old May 19, 2020
  #81
Civy01's Avatar
Civy01 is an unknown quantity at this point
Originally Posted by tristanlee85
I'm a few years too late, but I just did the LED tail lights and experienced this issue as well. Obviously cruise control no longer functioned, but also taking off from a stop simulated slipping in 1st gear (auto trans) and while sitting in park without the foot on the brake pedal, you could constantly hear the locking mechanism in the shiftselector clicking because it wasn't sure if your foot was on the pedal or not. This would allow you to shift out of park without depressing the pedal.
Which light (Brake light or signal?) and what specific wires did you attached the resistor to?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
h4ldol
Apr 24, 2017 08:16 PM
robjcivic
Mar 12, 2017 12:10 PM
cferry7
Oct 18, 2015 06:32 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
