Newb in the house!
So I got a 95 Civic DX and have been loving it for 2 months! So now after the past week it has started smoking pretty rough when I get on the gas, now I'm heart-broken...
What's you guys take on the cheapest way for a poor man to get this fixxed and back on the road? I'm soooo dependant on this car to get me back and forth to work and now I fear I will have to replace an engine....bty how nuch trouble to go VTEC head on my DX while I'm gonna have to eat this anyway? Or just leave the same? Any help appreciated!
Also where to get all this cheap?
Also where to get all this cheap? Re: Newb in the house!
What color is the smoke? White is a sign of coolant being burned off, which usually tends to be a head gasket issue. Blue smoke means the car is burning oil. If it's the latter, you could do a compression test to get a general idea of how well each cylinder is performing. There are threads on head swaps floating all over the net. Hop on Google or search here and you're bound to find something.
well...
you can either:
1) rebuild the engine (more likely you will know what condition it will be, but no car for a while)
2) Get an used engine with low miles (if at all possible), test compression it and if good, drop it in the bay.
Then you will have a working engine and a spare to play with or slowly build.
I believe i had the EX head swap in me sig, but it is for 7th gen, some differences might apply.
3) Go nuts and try a B-swap (also some instructions in one of the links in me sig.)
Buut, much mroe complicated and expensive.
you can either:
Styven Szastur
Sep 23, 2015 05:26 PM
pilebuck13
Sep 21, 2015 10:45 PM
Mannimarco
Sep 7, 2015 10:01 PM
honda.lioness
Aug 21, 2015 02:36 PM
jessica19699
Jul 29, 2015 05:51 AM
