Greetings.
Old Dec 19, 2010
plentyofz's Avatar
plentyofz is an unknown quantity at this point
Wink Greetings.
How goes it? This is my first honda and I learn how to fix things as they break. So far it's been simple. However, I've met a nut I can't get off. (yes, I know exactly how that sounds..)
The spindle nut holding in the (half?) shaft is cracked. I need to replace to the clutch, which means dropping the tranny, which means pulling out the shaft. Right? This F'n nut has busted a torque wrench, breaker bar, and laughs at impact guns (I'm convinced there just wasn't enough power behind them). It's bested 3 mechanic friends. Suggestions, oh Honda Gurus? *snoogins*
Old Dec 19, 2010
MindBomber's Avatar
Live for the Twisties
Re: Greetings.
Welcome, tried heat yet?
Old Dec 19, 2010
plentyofz's Avatar
Re: Greetings.
My brother suggested that. But I have never done anything like that, and am paranoid of damaging my bearings. I don't know anyone who enjoys changing those. Lol I have the torch, but no impact gun (which is what I was told to use after heating). Pointers? I'm not opposed to it, just leary..
Old Dec 19, 2010
02civicsi02's Avatar
Low and slow!
Re: Greetings.
Welcome and are you talking bout the axle nut.
Old Dec 19, 2010
MindBomber's Avatar
Re: Greetings.
I'm assuming your referring to the axle nut, since I've heard it called a spindle nut before.
Heat the nut up quickly, just enough for it to expand but not enough for it to get down the axle shaft, then try to take it off. If you need to you can heat up the entire nut fairly well, then quench it in the hopes that it won't contract to much during cooling.
If that doesn't work you could try cutting down into the nut itself with a dremmel, close to the thread but not close enough to cut into them, then use a chisel to break remainder of the nut off.
The axle nut is legendary, its one of the most difficult nuts on the entire car to remove, if your trying to take it off without an impact wrench your honestly wasting your time..
Old Dec 20, 2010
TRIZ's Avatar
Re: Greetings.
Anyone got a picture of this nuts location thats giving so much trouble? I'm a little lost on where exactly it is on the car
Old Dec 20, 2010
MindBomber's Avatar
Re: Greetings.
Thats the axle nut, which I believe can also be called a spindle nut.
Old Dec 20, 2010
ricky123's Avatar
ricky123 is an unknown quantity at this point
Re: Greetings.
Old Dec 20, 2010
mac25's Avatar
Dr Krieger of Modification
Re: Greetings.
is the car jacked up while you're doing this?
i mean if the other tire is on the ground the axel wouldn't rotate at all when you try. making it easier to get as much power to turn it as possible. like breaking bolts before you jake a car up to remove the tires.
i don't even know if this will help, just trying.
Old Dec 20, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Greetings.
When I had to remove this on my 92 accord we had no problem with an impact gun. Alas, if all else fails.. a bigger breaker bar Take it to the stealership and see if they can get it off for you.
Old Dec 20, 2010
Mad Dog Tannen's Avatar
Re: Greetings.
Never use a torque wrench to break torque!
Trust me, I work on aircraft for a living. Use a breaker bar, that's what they are for!
Old Dec 20, 2010
Low and slow!
Re: Greetings.
If the axle nut is giving such a problem and will not come off then just take the knuckle off and bring the axle with it. This would be easier. A breaker bar though should have gotten it though. Axle nuts are torqued down to round 130ish so its on there good. The impact gun though will get it off no problem.
Old Dec 20, 2010
Re: Greetings.
A breaker bar with cheater bar attached to it should work.
Old Dec 20, 2010
MindBomber's Avatar
Re: Greetings.
Before I bought an impact wrench, my breaker bar-cheater bar combo was one of my most useful tools.
Old Dec 22, 2010
plentyofz's Avatar
Re: Greetings.
you all are amazing! I was also told to try Kroil, a creeper oil, then impact. Has anyone used that before?
Old Dec 22, 2010
TRIZ's Avatar
Re: Greetings.
Nope, use an impact gun, that thing will fly right off of there in .24673 seconds.
Old Dec 22, 2010
Re: Greetings.
Liquid wrench or PB blaster or any of those penetrating oils will help too. Spray them and let it set for a day then try to break it loose.
MrOldskool
Feb 26, 2015 07:03 PM
EX-Dave
Jul 5, 2014 11:13 AM
dookietwo
HIDs and Retrofitting
Jan 24, 2014 11:42 PM
RobbieRob008
May 1, 2013 08:39 PM
obieone
Feb 17, 2013 09:58 AM
