2004 Civic Headlight Output Improvement Question
Old Dec 4, 2020
Yardstick's Avatar
Yardstick is an unknown quantity at this point
My parents have a 2004 Honda Civic with cloudy headlights. They have tried polishing them but the haze returns too quickly. I started looking into aftermarket replacements hoping to find some LED based housings. If there is one, I haven't found it yet. CarID shows options from Spec-D, Anzo and CG but they are all some combination of H1/H3 projector. So far I haven't found any beam pattern comparisons to stock with any of these brands. Are any of them better than stock? Or is there any other simple way to improve the headlight output on their Civic?
Old Dec 4, 2020
Colin42's Avatar
Re: 2004 Civic Headlight Output Improvement Question
New housings and LED bulbs, you "should" use proper projector housings. I didn't, never got flashed
Old Dec 4, 2020
Yardstick's Avatar
Which LED bulbs did you use? I've been staying away from that solution because LEDs never seem to be designed quite right for housings meant for Halogen bulbs.
Old Dec 4, 2020
most aftermarket projector headlights suck at light output.
My old Amzo's were among them.
HID conversion - requires manual work
https://www.civicforums.com/forums/2...1-install.html
04 is still not projectors, so would not recommend led bulbs. They would blind other drivers, likely
about leds, not sure how true, but interesting watch here:
the part that the chips need to match filament position/size sounds quite true
Old Dec 4, 2020
Yardstick's Avatar
I actually watched that video earlier before posting. I've always heard and even experienced the limitations of alternate type emitters needing to match the position/focus/size of the halogen emitter. I have tried HID and LED retrofit bulbs in motorcycle housings for off-road use to get better lighting. It's kind of an improvement in those, but the scatter and blinding others is less of a concern there. It sounds like LED bulb retrofits are improving, but there are so many out there that it's difficult to know which one to choose. I'm leaning toward suggesting OEM housings with brighter halogen bulbs.
Old Dec 4, 2020
one thing that works is a proper clear coat over the lights to keep them from hazing - mine were poorly coated (my own fault, i guess, but lasted longer than without) - i suck at body/paint/electrical work
Old Dec 4, 2020
check out HIR bulbs. 9011 and 9012 can replace the. stock bulbs 9005 and 9006, i think just one slight mod to do it
Old Dec 4, 2020
Colin42's Avatar
Hakari, they threw way more light than stock.
Old Dec 5, 2020
Yardstick's Avatar
Do you happen to have (or could you get) a picture of how they illuminate a road?
Old Dec 5, 2020
Colin42's Avatar
Nope car was written off last October. At least 30% farther and wider compared to stock. I did both the high and low beams
Old Dec 6, 2020
Yardstick's Avatar
That's a bummer. I'll suggest they try those LEDs. Thanks!
pwnsauce
Lighting
Aug 24, 2011 02:05 AM
McPhantom
Jun 2, 2008 04:40 PM
sleepyj
Sep 12, 2007 07:34 PM
legend921
Nov 19, 2005 09:22 AM
SinaloaCivic
Lighting
Sep 29, 2005 03:07 AM
