Cluster bulb size?
Old Feb 13, 2012
stock's Avatar
stock is on a distinguished road
Cluster bulb size?
Hi,
My 2002 Civic sedan has a blown bulb on my cluster around the top part of the speedometer area. I haven't taken the cluster out yet.
Apparently there are 3 different bulbs on the cluster.
007 SOCKET ASSY., BULB (14V 3W) 78180-S5A-A01
008 SOCKET ASSY., BULB (14V 1.26W) 78181-S84-A02
009 SOCKET ASSY., BULB (14V 1.4W) 78182-S84-A02
Honda wants me to prepay $10 each and no refunds if i get the wrong bulb.
Anyone know what size bulb I need? I thought the bulbs were all #74 bulbs. Can I find these bulbs cheaper at NAPA and what are the equivalent part numbers?
Thanks.
Old Feb 13, 2012
CraigW's Avatar
Re: Cluster bulb size?
Could not really tell by the part #s ( the 3 watt may be illumination ??) they all say w/socket.
I would get some #74 bulbs they will be cheaper.
Twist left to loosen socket, bulbs pull straight.
Old Feb 13, 2012
stock's Avatar
Found diagram online.
http://estore.honda.com/honda/parts/...&b=B++1211&dl=
Maybe I need a #8 bulb in the diagram? Does the wattage matter as long as the bulb fits?
Old Feb 13, 2012
CraigW's Avatar
Some bulbs (indicator lights) are neo-wedge type and the come as a socket & bulb combination and you have to replace them as an assembly.
The illumination bulbs can be pulled from socket and you can replace just the bulb.
I would go with #74s from the car parts store, get 6 and change them all at once
Old Feb 13, 2012
lazlong's Avatar
Yes, more wattage= brighter bulb. Next time you're at the salvage yard just pick any vehicle from the 80's or 90's and it should have the same bulbs. You can get a handful for a dollar or two. Or free if your pockets are deep enough (I didn't say that). lol
hondacivic0253
Sep 29, 2015 08:06 AM
rayman009
Sep 12, 2015 08:30 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
