heat / cooling control knobs
Old Jan 31, 2012
fgrandt's Avatar
fgrandt is an unknown quantity at this point
heat / cooling control *****
Just bought a 2003 - the heating and cooling ***** are not illuminated. I expect that they should be. Specifically, the Mode Control Dial, the Temperature Control Dial, and the Fan Control Dial. Is there a single common bulb? How do I get to it?
Old Jan 31, 2012
CraigW's Avatar
Re: heat / cooling control *****
Various neo-wedge bulb/socket assmblies are used.
Use the parts websites with your body style and trim level to locate exact part #s.
I did all of my bulbs at the same time on my 05.
Removal = same procedure as audio unit change, It's all here.
Old Feb 1, 2012
electric130's Avatar
Does it have an aftermarket stereo? If so, pull it out and check if the "illumination" wire is connected. If it is, that's your problem.
mistermenphis22
Jul 13, 2015 04:43 PM
juan830
Jun 17, 2015 10:55 PM
cooldan1
Apr 23, 2015 10:49 AM
pimpedcivic
40
Jul 23, 2002 11:41 PM
Microbiology
Nov 9, 2001 10:10 PM
