Fog Lights
Old Sep 14, 2011
SSMCivicCoupe's Avatar
SSMCivicCoupe will become famous soon enough
Fog Lights
Hey, so ordered fog lights for my civic, and i searched around and found out that i can directly wire them to my parking lights so that they turn on with my parking lights but i had one question, which parking light wire do i tap into, i checked the wires that go to the bulb and their are three wires one black, one green, and one red. So which one can i tap into that will make the fogs turn on with the parking lights? Thanks
Old Sep 14, 2011
iridehonda's Avatar
iridehonda is an unknown quantity at this point
Re: Fog Lights
Just a complete guess, but when dealing with electronics, red is universally the hot lead. Tap into it and try it out.
Old Sep 14, 2011
Re: Fog Lights
Ye i was thinking the same but i didnt want to short anything, so im just going to wait and see if anyone knows for sure what wire will be ok to tap into.
and also forgot to mention the the Green and red wire have a yellow line going through them.
Old Sep 14, 2011
iridehonda's Avatar
Re: Fog Lights
After doing some searching it seems the green and red are both power leads. Still haven't found exactly which one you should splice into but I'll keep looking. Maybe someone else will post an answer in the meantime.
Edit: I found one thread on another forum saying to tap in to the red wire. I can't share the link due to a site filter. If you still want to wait I'm sure gearbox will have an exact answer for you. Sorry I couldn't be of more help.
Old Sep 19, 2011
Resmondo's Avatar
Resmondo is an unknown quantity at this point
Re: Fog Lights
here is the wiring diagram for the turn signal/hazard lights
should be an attachment
Old Sep 19, 2011
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
Re: Fog Lights
When you say you want to wire the fog lights so they turn on with the parking lights I hope you still plan to use the relay. If you splice the fog lights into the same wires as the parking lights you are pulling more power than the circuit was designed for and risk blowing fuses and burning the switch contacts for the parking lights.
Old Sep 20, 2011
electric130's Avatar
Re: Fog Lights
that's only the turn signals. if i remember right, i think it's the RED/YEL wire that has power for the parking lights. you'd want that to go to the 85/86 terminal of the relay. i'd HIGHLY recommend putting a switch in line with that though. if you leave the switch on, the fogs will come on with the parking lights. however, there may be times you need to turn them off.
Exterior
Nov 28, 2025 05:23 PM
XXLUV2EXCELR8XX
Dec 16, 2001 04:56 PM
LuvMyCivic
Dec 12, 2001 10:02 PM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
