7440 turn signal bulb on a 02 coupe EX
Old Mar 9, 2010
hi, i am trying to fit a 7440 amber bulb on a clean lens front turn signal connector.
I was expecting it to be a direct fit and tried to push it in, but it stopped midway. A closer inspection against the original 7443 shows that the locks are in different positions in the 7440, which i am assuming is the cause for not pushing all the way in.
Is there a different connector that works with 7440 that could fit my headlight assembly that somebody knows of?
I could always grind the locks off, or the connectors itself, but sort of short in time to mechanical inspection here in Canada (car is originally US).
Naturally i could try to fit another amber bulb but i will need to open the headlight housing to make the bulb pass thru the hole... ( the other type of bulbs are larger diameter, but fit the connector... Aaaah! where is the interconnectivity?!? cars are expensive because everyone wants to design a different "universal" part!).
Not really looking for opening the headlight housing - this are the Amsa USA projector set, so since they are not leaking or accumulating moisture for 2 years, would not like to try my luck...
sorry for long post, but thought more info could help pinpoint solutions.
thanks
sandro
Old Mar 10, 2010
Re: 7440 turn signal bulb on a 02 coupe EX
grinding the tabs on the bulb with a dremel is easiest if they are all glass. otherwise check ebay for seller "autopartshouse" he has 7443 and 7440 natural amber bulbs with a plastic base and ive tried both at one time. they fit perfectly in the stock connector.
Old Mar 10, 2010
griding them right now, thanks gearbox
Old Mar 10, 2010
glass is harder than metal... 2nd lime now... and will need to de-greaser afterwards... Wah!
Worth the work, though...
Old Mar 10, 2010
yeah take it slow, you dont want the glass cracking from heat buildup.
Old Mar 10, 2010
yes.
but there's still the spare one...
good news? they are real colored glass, since same color after griding. not surface coating.
Poopies
Apr 20, 2017 11:36 PM
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
SWEETRIDE
Nov 27, 2001 05:52 PM
Dagooseisloose
Nov 9, 2001 10:18 AM
