Map, dome and trunk light swap
Old Sep 18, 2006
Slawek's Avatar
Proudly Canadian
Slawek is an unknown quantity at this point
I'd like to swap my map, dome and trunk lights in my 2004 Civic Coupe.. I have 3 lights right above my head (2 map + 1 dome), then I have one more dome above the back seats, and then I have a trunk light too. Also I'd like to replace the bulbs above my license plate with white LED's too if possible...
Can you guys provide me with a link for some LED lights that will give off white light, not yellowish like I currently have? I want to swap all the lights. And if possible, let me know what part #'s I need, because I have no idea!
Thanks!
Old Sep 19, 2006
leds are a bit weird. i tried some to make the light whiter, its not a pure white but more of a blue tint to it and even the best leds are not nearly as bright as regular bulb. so you wont have light to see with either. stick with coated bulbs that give a white color like raybrig hypers, or just turn off the dome lights if you dont need em.
Old Sep 20, 2006
Slawek's Avatar
Proudly Canadian
Hmm can you point me to a seller of these Raybrig lights for Honda applications? I am having a hard time finding these... someone who ships to Canada
Old Sep 20, 2006
d-thug's Avatar
Support Our Troops -Avenge 9/11
d-thug will become famous soon enough
ledautomotive.com that's where I got my blue dome light at, they should have white. good stuff
Old Sep 20, 2006
try www.racinglab.com autolumination.com or ebay shops.
Old Mar 23, 2008
CivicIvy's Avatar
CivicIvy is an unknown quantity at this point
Re: Map, dome and trunk light swap
can anyone let me know the bulb type for map lights and dome light for 2004 Civic Coupe?
Old Mar 23, 2008
check the owners manual, its different for ex vs lx and dx and also if you have coupe or sedan. i think ledautomotive.com has the sizes figured out tho.
Old Mar 23, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
I tried to find the Dilbert strip with the book about the Spanish Explorer but couldn't find it.
Old Jun 4, 2008
Dirty4Door's Avatar
Dirty4Door is an unknown quantity at this point
Civic Bulb Tables
there's quite a nice layout of all the bulbs for 1992-2008 civics here:
http://www.eautoworks.com/html/bulbS...ONDA-Civic.htm
...just click on your year.
Old Jun 4, 2008
Dirty4Door's Avatar
GEARBOX: on the front dome light...
i currently use one layer of red brakelight tape on the inside lens of the dome light (dome only) which gives off a dim red light (for its neutral, night-vision-retaining hue) which is great, unobtrusive, not bright, and doesn't appear illegal...
but, it's still red tape on a white light = a slightly more pink hue than red.
Would you recommend a red colored Incandescent or LED in the dome, in your opinion? I am not looking for bright, which is why red (neutral-hued) is my choice. Also, since sites don't offer Dome Part #s for 04-05 sedans, do you know if the 05 dome bulb is the same as 01-03 sedans since the housing appears to be the same?
Old Jun 4, 2008
TRIZ's Avatar
Piaa makes some, the dome from the 6th gen vic fit the 7th gen.. but the hyper white bulbs of theirs look white when illuminated behind the lenses, but yeah they give a blue hue.... which sucks. Coated bulbs are like a really shitty florescent light. They look bad. Stick with the stock bulbs.
Old Jun 4, 2008
leds are the best cause they put out true colors at a single wavelength. i have single 1 watt amber led in mine
Old Jun 5, 2008
Dirty4Door's Avatar
wow, that looks nice. much nicer than red tape. i think i'll go with red, but am i replacing with a 194 wedge? or 125 as TRIZ (and the above link for 2001-2003) states?
Old Jun 6, 2008
if you have the same front dome light as i do, they all take 194. be sure to get a 1w led, the other ones are very dim. here get it from ebay or autolumination.com and it will be pure red.
Old Jun 18, 2008
chavalo89's Avatar
chavalo89 is an unknown quantity at this point
Let us know how your search goes.
I want to put white leds in the dome and map lights as well, just havent got round to looking for them.
I got blue bulbs for number plate, looks classy.
It reflects off white plate .
Still wanna know if the inside lights will be bright.
Old Jun 18, 2008
you gotta stick with the 1w+ leds and they will be bright.
Old Jun 19, 2008
Eps's Avatar
Eps
Eps is an unknown quantity at this point
If you're in the Ontario area looking for LED swap, there is Battle Endless and their Dome Lights from REI Lighting.
http://www.battleendless.com/
I'm not sure if they ship out, but I'd guess they would?
They are sorta pricey though, $25 for one set.
Stock
After
Comes with this, and double-sided tape.
Old Jan 20, 2009
usmcdevilmp's Avatar
usmcdevilmp is an unknown quantity at this point
Wow I think that looks really good
sccarally
Texas
May 17, 2015 10:11 PM
twtron
Apr 17, 2015 12:09 AM
wawacito
Nov 5, 2001 03:32 PM
meels808
Nov 5, 2001 09:15 AM
TropiKalCiviC
Sep 25, 2001 07:02 PM
