HID projector headlight problem!! Help!!!
Old May 10, 2006
hauliau's Avatar
hauliau is an unknown quantity at this point
Hey Guys,
I bought the below projector from ebay, and I saw the low and high beam are H1 bulb. So I ordered the HID H1 also, but then the HID doesn't fit the hole of the headlight, but the regular H1 bulb fit just fine. I noticed that the headlight had a small sticker saying HID bulb it's not allowed, I wonder why. Any of you guys have experienced with this. Any advice is appreciated. Thanks
Headlight
HID
Old May 10, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
I also have dual halo projectors, so I was wondering about this also. I believe that to get HID's, A different projector needs to be retrofitted into this headlight housing. The problem is I don't know if that's possible. I would hope so but I'm not sure...
Old May 10, 2006
2k2_civic_ex_4d's Avatar
2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold
Ok, first of all that projector is designed for a halogen bulb, even if you manage to get the Hid bulb through the hole you will get very poor output. Second the Hid capsule is longer and fatter than the little one that makes up normal h1 bulb so it'd probably end hitting the cut shield anyway.
Old May 10, 2006
civicstylez's Avatar
civicstylez is an unknown quantity at this point
yup jus retrofit them with valeos looks like they'd fit ....
Old May 10, 2006
R1Style's Avatar
People are using H1 HID kits on the TYC projectors just fine. They also had problems with the bulb not fitting through the the hole so they just made the opening bigger with a file or dremel.
Old May 10, 2006
hauliau's Avatar
How'd you do that ?
Old May 10, 2006
jay78's Avatar
jay78 is on a distinguished road
retrofit is the way to go.....buy oem kit.....
Old May 10, 2006
dirtySAMURAI's Avatar
I log in from time to time
moved to lighting
Old May 10, 2006
hauliau's Avatar
Wow!! to retrofit the headlight seems like a lot of work. Can I just use dremel to make the fitting hole bigger and fit the HID? What the effect from that?
If I decided to do the retrofit, what is the thing that I need to buy? Is there any retrofit topic in DIY?
Thanks
Old May 10, 2006
http://retrofit1.dirtysamurai.com/
^Retrofit DIY
Old May 10, 2006
jay78's Avatar
Thanks
retrofit is very easy specially if u retrofitting valeo projectors....they are very easy......hard part would opening your headlight.....then that....all your hve to do is the drill a hole bit bigger on your valeo lens holder and thats all...
Old May 10, 2006
hauliau's Avatar
I think I know what I am gonna do to my headlight now. If everything turns out great I will post some pics of my HID. I never try the halogen H1, are they bright enough for normal night driving?
Old May 10, 2006
jay78's Avatar
h1 gives very poor light out put........h4 is better then h1...........
Old May 11, 2006
dp_yz713's Avatar
Boobies are the mans tinkertoys
dp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to behold
yah h1 is just fine for driving. its the cheap projector that makes the light output crappy
Old May 11, 2006
hauliau's Avatar
Man, I just wished there is a shop here in town that would do this.
Old May 11, 2006
dp_yz713's Avatar
do what? a retrofit or install them. cuz all you gotta do is plug wires to install. just like changing the bulb
Old May 11, 2006
hauliau's Avatar
I meant retrofit. I wonder if you guys ever just use hand file to make the fitting hole bigger and fit the H1 HID into it.
Old May 11, 2006
dp_yz713's Avatar
yah you could. use that or a dremel
stryder12
Jun 30, 2015 08:33 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
intensity
May 12, 2015 10:43 PM
shaejb15
Apr 26, 2015 07:44 PM
Hondasport01
Dec 17, 2001 01:53 PM
