2002-2004 SiR Bulbs
Old Mar 29, 2006
SiR_Tuner's Avatar
SiR_Tuner is an unknown quantity at this point
2002-2004 SiR Bulbs
I just wrote a huge post and it got eaten so i'll keep this short and sweet.
I have two souces online saying I need 9006 or 9005 bulbs and I've looked through the headlight and I read 9003... now I went to the store and 9003 are like the hardest to find here, so i'll have to order away... now I want to be damn sure i'm getting the right model and some decent lights.
Please Help.
Old Mar 29, 2006
rjngo's Avatar
rjngo will become famous soon enoughrjngo will become famous soon enough
im guessing that your looking for the headlights right? high/low beam?
Old Mar 29, 2006
SiR_Tuner's Avatar
yes, Headlights.
Old Mar 29, 2006
rjngo's Avatar
what year is your car?
Old Mar 29, 2006
SiR_Tuner's Avatar
It's a 2003 SIR
Old Mar 29, 2006
rjngo's Avatar
its 9003 for 2003.
if it was 2004 then it would have been 9006(low beam) and 9005(high beam)
Old Mar 29, 2006
SiR_Tuner's Avatar
its 9003 for 2003.
... so, it's high and low beam in one bulb? Is that why they cost so much more than the 9006s?
Old Mar 29, 2006
rjngo's Avatar
yeah...its dual lighting system
Old Mar 29, 2006
SiR_Tuner's Avatar
Excellent. Thank you... now I have to find some bulbs and see if they are legal.
Old Mar 29, 2006
rjngo's Avatar
^ no problem
Old Mar 30, 2006
just take off the bulb and look, or just look through the headlight from the front. all bulbs are required to have the type and wattage on them.
Old Mar 30, 2006
Mystic3030's Avatar
Yup, i'm an A$$hole.
9003 bulbs may also be labeled H4 depending on the manufacturer.
Old Mar 31, 2006
82801BA's Avatar
82801BA is an unknown quantity at this point
Theoretically it's illegal to put H4 into 9003 housing (marked HB4 on the lense) due to "too much variance in the position of the filaments within the bulb." I think it transfer into glare and effective lighting distance issue....H4 is essentially an ECE light and 9003 is the DOT light and therefore it's illegal to use H4 in U.S. theoretically.....What I mean is that there's NO DOT H4 bulb (H4 and DOT mark alone), but there can be "H4 ECE 9003 (HB2) DOT" bulb (has both H4 and 9003 (or HB2), plus ECE and DOT mark all together) and "9003 DOT" or "HB2 DOT"...HB2 is just another name for 9003....
Quote from http://www.candlepowerinc.com/pdfs/H4_9003.pdf
Old Apr 1, 2006
ya the H4 osram silverstar I use are ECE but they work fine in projectors so no worries.
Old Apr 6, 2006
Mystic3030's Avatar
The Silverstars I have say H4, not 9003, and are DOT aproved. Also, he's in Toronto Canada, so the DOT labeling won't apply.
cferry7
Oct 18, 2015 06:32 PM
shaejb15
Sep 12, 2015 01:02 AM
duhwubwub
Sep 10, 2015 11:00 AM
MamaBear2015
Sep 4, 2015 09:04 PM
j-chest
Aug 11, 2015 02:26 PM
