Taking apart Dome light/map lights
Old Mar 4, 2006
2005SE
Guest
Posts: n/a
How do you take apart the dome light and map lights? I need to replace some bulbs...and I searched but I got nothin'. Any help will be appreciated!
Old Mar 4, 2006
2005SE
Guest
Posts: n/a
I've got to get this done tomorrow morning...please help, otherwise I'm going in with a flathead screwdriver to pry them off....If you want 1000 points or whatever for the first correct answer I will facilitate...I have an '05 Coupe....please be specific with your instructions!
Old Mar 4, 2006
hdave's Avatar
hdave is an unknown quantity at this point
dome light: just use a flathead and pry it off
sorry dont know about maplights but im almost certain its the same
Old Mar 4, 2006
2005SE
Guest
Posts: n/a
Thanks hdave for the quick response...I will give it a shot tomorrow and give you your points soon thereafter!
Old Mar 4, 2006
hdave's Avatar
no need to gimme points lol, i didnt do nothing
Old Mar 5, 2006
2005SE
Guest
Posts: n/a
Alright, then rep for ya. I'm going to change the bulbs now. Thanks again!
Old Mar 5, 2006
its all the same piece. there is a tab in the middle of one side. just stick in a small flathead screwdriver and pry it off. then it pops back on just make sure you put the tabs in first.
Old Mar 7, 2006
2005SE
Guest
Posts: n/a
Right you are about the tabs, but on my 05 LX SE coupe, the dome light is separate from the map lights. My map lights are right above the rear-view mirror and my dome light is in the middle of the ceiling of the car. Thanks for your help, though!
Old Mar 7, 2006
PunkingCivic's Avatar
I need TP for my bunghole
don't know but here is a picture:
http://www.hondaautomotiveparts.com/...INTERIOR+LIGHT
Old Mar 7, 2006
ya sorry the EX is all one piece. lx/dx has separate map lights.
Old Mar 14, 2006
paradoxblue's Avatar
when u cant fnd a ****. push thingy or button on a civic piece. pryt he lil basterd off.
or thats how ive found things to work
Old Mar 15, 2006
R1Style's Avatar
Don't just pry anywhere on the map lights off you'll break the tabs.
Ok to take the map lights off, easiest thing to do is push and HOLD the map light on or off (you know how you push the outside of the actual light to turn them on/off). When you push and hold it, the opposite end (the inside of the maplight), you will see a gap, use a knife or flat head screw driver wedge it in the gap and pop it out. That's it.
EDIT: here's my ghetto diagram
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
twtron
Apr 17, 2015 12:09 AM
wawacito
Nov 5, 2001 03:32 PM
meels808
Nov 5, 2001 09:15 AM
TropiKalCiviC
Sep 25, 2001 07:02 PM
