18 ohm alot?
Old Feb 19, 2006
18 ohm alot?
I'm in the process of testing 1 watt LED and i calculated that it needs an 18ohm resistor. the problem is after a few seconds the resistor gets too hot to hold, and would prolly destroy itself quickly anyway. Is 18 ohm even enough to make a difference or should I run the led without resistor?
Old Feb 19, 2006
CraigW's Avatar
Check out www.candlepowerforums.com Not a member there but have seen some neat stuff posted.
JetsterDajet
52
May 8, 2016 12:11 AM
chiquita.banana
Sep 24, 2015 09:42 AM
BBrosario
Sep 17, 2015 07:51 PM
EM2661
Sep 11, 2015 06:01 PM
