White light, CLEAR bulbs
Old Feb 15, 2006
GL6570's Avatar
GL6570 is an unknown quantity at this point
Hey, im new to the board and I'm thinking of clearing out my lights and changing my stock lights to something whiter. I was thinking of getting the Mtec whites for my 2005 civic but It seems like the bulb has that blue tint to it and I don't like how the blue reflects onto the reflector during the day. Can anyone suggest any bulbs that are just as good as mtecs but clear insted of blue?
thanks in advance!
Old Feb 15, 2006
um there is no clear bulb that can produce a color as white as mtec. The best clear bulbs are philips vision plus and osram silverstar (not sylvania). I have the philips and they are very bright, but you won't get the white look you want. Throw on an upgraded harness and it will make them whiter than stock, but not by much.
Old Feb 15, 2006
philips vision plus
Old Feb 16, 2006
GL6570's Avatar
hmm, I'll just suck it up and stick with the mtecs then.
BTW, is there any particular paint that I should be using to paint the amber reflectors with? Maybe like a chrome paint or would regular silver spray paint work fine?
Old Feb 16, 2006
paint the reflectors? how does that work.usually people just open the headlight and pull it out.
Old Feb 16, 2006
GL6570's Avatar
I read on this board that you have to paint it and put it back on or there will be a big hole in there. Is that not true? and without it wouldn't the turn signal lights flash into the actual headlight area. Sorry if im really newb at this, i've never opened up a civic headlight and looked at it.
Old Feb 16, 2006
oh yea that is true for 04-05 headlights not 01-03. you can leave em in or take em out.
Old Feb 16, 2006
GL6570's Avatar
alright, I guess i'll be looking around for some chrome spray paint. Thanks for the help gearbox.
Old Feb 17, 2006
TemjinX2's Avatar
yeah i would prime it and just paint it with some high temp paint. I would just leave it though. The amber is barely noticeable when you compare it to the 01-03. You can't even see the amber piece from my old pics of my car. I don't think its worth the effort just to paint the amber piece unless your blacking out your headlights too.
Old Feb 17, 2006
GL6570's Avatar
So you're saying that I shouldn't clear my lights? just leave them alone?
Old Feb 17, 2006
TemjinX2's Avatar
for me i dont think its really worth the effort just to paint one piece. If you plan on blacking out your headlights then i would just do both at the same time.
Old Feb 23, 2006
arabianknight's Avatar
arabianknight is an unknown quantity at this point
hey anyone here change out the amber bulb on the turn signals to something whiter? i jus upgraded to high and low beam silverstars and i wanted to whiten out the amber turn signal bulb to finish it off. i think the bulb is 1157 and i saw that sylvania made a silverstar bulb in 1157. anyone tried it and does it match up with the silverstar headlights? any suggestions on good, bright white turn signal bulbs. do they look good?
Old Feb 23, 2006
no the silverstar signal actually flashes orange
Old Feb 23, 2006
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
osram silverstars are the same thing as sylvania silverstars
same company osram is a german company that bought out sylvania (american company)
Old Feb 23, 2006
yea osram silverstar is the good clear bulb with more light, sylvania is the ricer bulb with coating and less light.
Old Feb 26, 2006
GL6570's Avatar
soo uhh, since we're on the subject of doing my lights I was wondering if its possible to wire factory fog lights(I don't have them yet) to my regular headlights so the fogs come on with the headlights. Also, are there any fog bulbs that can match the color and brightness of the mtecs? If not, can anyone suggest some that come close to it?
Old Feb 26, 2006
just leave the switch pushed in and they will come on with the headlights. oem only works when headlights are on unless you modify the switch.
Old Feb 26, 2006
GL6570's Avatar
alright i'll just do that then. can you suggest any good bulbs that would match the mtecs or come close to it?
Old Feb 26, 2006
Luk's metal white
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
bahena08
Apr 11, 2015 05:09 PM
SWEETRIDE
Nov 27, 2001 05:52 PM
wawacito
Nov 5, 2001 03:32 PM
sonsonzai
Nov 4, 2001 12:52 PM
