HID Highs 9005
Old Nov 25, 2005
veloz's Avatar
veloz is an unknown quantity at this point
HID Highs 9005
Does anyone have an aftermarket HID kit installed in the factory 04-05 coupe headlight housings? I've searched the lighting forum and I've heard some people say that HID highs are a bad idea because (1) there's no shield in the factory headlight housing for the high beam and (2) the constant on/off action of highs can damage the bulb/ballast/igniter. Plus I don't know about the glare from a reflector beam housing with HIDs.
Any comments? Also, if anyone has pics....please post.
Old Nov 25, 2005
MegaHurtz's Avatar
How often are you going to use your high beams that you need the HID kit? Waste of money IMO, HID is not meant for high beam
I have a 9006 HID kit and it works fine, but I would never spend the money for a high beam kit.
Old Nov 25, 2005
veloz's Avatar
I agree that its probably a waste of money. The reason I asked is because I'm sure that I saw a picture of somebody with an 04-05 with highs and lows. With high beam HIDs in a reflector beam housing, if you ever forgot to switch off the highs, you'd probably blind anyone driving toward you.
Old Nov 25, 2005
mikem317's Avatar
mikem317 should not be trusted
I have them installed in my low beams. In dry conditions, I can see probably four times as much compared to the stock hallogens. I have the stock hallogens in my high beams. I've used them several times with the HIDs on just to get a bit more light (very dark road at night). I might get some PIAAs or similar bulb or the highs, but I don't find myself using them often enough to justify that purchase. There's a lot of glare in the pictures but the camera really amplifies the glare, IMO.
Old Nov 26, 2005
hdave's Avatar
hdave is an unknown quantity at this point
i want some HID fogs
Donahue
Sep 8, 2015 09:00 AM
7thgensurvivor
Aug 28, 2015 08:39 PM
MamaBear2015
Aug 25, 2015 10:47 AM
adamdrives
15
Aug 8, 2015 08:53 PM
silentz
Jul 9, 2015 08:16 PM
