omg help projectors alignment
Old Aug 16, 2005
scarypunk's Avatar
scarypunk has a little shameless behaviour in the past
so i have just installed sonar projectors and there is 3 pillar type bolt things on the back.. i am turning them to get it to aim right, but i cant seem to move the night time light, just the high beams.. what gives? ..
can someone help.. as i have my bumper off and my light sitting on a box. ( i cant get to the screws with it installed.)
Old Aug 17, 2005
streetglower's Avatar
Moved to the Lighting forum
Old Aug 17, 2005
PennyKnotOff's Avatar
on the back you got three screws for the high beams and two for the projectors right?
Old Aug 17, 2005
scarypunk's Avatar
there is 3 screws on the back yes, but i only notice movement with one of the screws .. it moves the high beams.
Old Aug 17, 2005
the set of 3 screws are for the high beams and the set of 2 screws are for the low beams (the projectors). For high beams the screws to the right and left move the beam right and left and the one screws on the bottom moves the beams up or down by tightening and loosening the screws. Now for the projector you only got the two screws and what you gotta do is tighten the right and left screws evenly and that will move the beam up and down. It may take some time to adjust everything. I suggest parking your car in front of a garage and mark off where you want the beams to be on the garage and start from there. Hope this helps
Solo Flow
Oct 4, 2015 07:52 AM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
TheRiddicles
Sep 21, 2015 01:28 AM
