TYC projectors yay or nay?
Old Jun 17, 2005
R3DL1N3's Avatar
recently my driver side head lamp fogged up with moisture so i figured it would probably be cheaper to buy a set of TYC black projectors off ebay than to go buy a single head lamp at honda. has anyone had any problems w/ their tycs? im sure this topic and been discussed many times, but i had to post because no search came up. also is there any modifications that need to be done or is it strictly oem fitment?
Old Jun 17, 2005
Karumba's Avatar
Boredom causes changes ;)
It'd probably be cheaper for you to open up your headlights and reseal them properly.
My TYCs were oem fitment, no problems whatsoever installing. However, after a good while, a spider decided to make a home in my driver side. And then again being mentioned by another owner, I started noticing fogging happening after rainy days and running them for long periods. The fogging doesn't stay, but others have original sealant issues. *IF* you buy the TYCs, I'd suggest running an extra bead of silicone around the edges. But I would suggest you go the cheaper route of resealing your own headlights first.
Old Jun 18, 2005
dirtySAMURAI's Avatar
I log in from time to time
wingsfan19
Oct 1, 2015 03:45 AM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
marux
Mar 24, 2002 06:13 PM
jimmymingdahai
Mar 20, 2002 04:00 PM
marux
Feb 22, 2002 02:06 PM
