Headlight beeping sound
Old May 27, 2005
chibitul's Avatar
chibitul is an unknown quantity at this point
Hi,
I have a Civic 2001 LX. I "think" there was a beeping sound when I forgot the headlight ON, but I am not sure. Anyway, my wife forgot the lights ON and the battery was dead..... AAA came to resque!
Questions:
1-is there supposed to be a warning sound when you forget the headlights ON???
2-if yes, how do I re-enable it? I think it might have been disabled when I turned off the auto-AC for DEFROST... maybe?
3-can I build one myself?
THANKS!
Old May 27, 2005
drew22mader's Avatar
There is gl@ss in my @SS...
Yes, a beep will sound and continue to sound until you turn them off. I don't think you disabled it though. Might check fuses. Not for sure though
Old May 27, 2005
dirtySAMURAI's Avatar
I log in from time to time
1 there is a high bitched buzzing noise if you leave the lights on and your driver's side door is open.
2 if it wasn't there in the first place, then don't expect it to come back...
3 sure. but it involves relays and stuff...that i dont understand lol
Old May 28, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
Originally Posted by chibitul
Hi,
Questions:
THANKS!
I have an 01 LX and it will make a noise if you leave your lights on.
does your dome light turn on when you open your car (assuming you have the switch set to door)?
if it doesn't, its just the door jam sensor, its that small rubber black nub on your door, there about $12 cdn at your local honda dealership. Installations easy I had 2 break on me already
oh yeah, and its not a beeping noise its one solid beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep
Old May 29, 2005
Ed's Avatar
Ed
I have an 01 lx, i did the lil AC defroster thing as well, it still beeps at me when i try to leave with the lights still on.
Old May 29, 2005
pretty sure its that door jam sensor, the lights aint beeping because it doesnt know if the doors open or not
Old May 29, 2005
LudlamTheory's Avatar
i boogie for the raindrops
check the fuses...
Old May 29, 2005
i hate that beeping. is there a separate fuse I can pull for it to stop?
Old May 30, 2005
chibitul's Avatar
Thanks, it was the door switch! I think it was oxidized or something, it seems to work now. But just in case I swapped it with the one from the read door, I don't use that door much anyway... maybe someday I will pick up a new one, I don't have time now...
Thanks again, good advice and great web site!
Old May 30, 2005
CraigW's Avatar
You should be able to clean it up somehow, I have not looked at any of the new style switches.
Thanks for letting us know what you found.
Old May 30, 2005
you should really replace that sensor if you have an alarm system, or anything to protect in your car. Those sensors also trigger your alarm (which you dont have if your bone stock) so it comprimises the security of your vechile.
although a theif probably wouldn't know which door. Your passenger door is going to die next, :P
Old May 30, 2005
chibitul's Avatar
Good point. I don't have a car alarm, I don't leave any valuables in the car, and I live in a farly decent place (although a few blocks away it's pretty scary!).
Thank you all! (and my Wife also says THANK YOU, she felt guilty when she forgot the lights on).
15EXCoupe
Jul 30, 2015 12:59 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
Ariah J. Davis
Jul 20, 2015 07:15 AM
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
Hqly2001
22
Jul 12, 2015 06:44 PM
