Can't get reflectors out...
Old May 13, 2005
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
Hey guys soo I finally took my headlights apart. Now i'm kinda stuck...and my fingers are hurting bad...lol
I got my headlights apart...and now I dunno how to take the reflector bowls out...these are 05 civic headlights...and as far as I can see there are 3 mounting points. I've included pics, one is a side mount, one is a top, and one is a bottom. The bottom mount has a screw that u can turn from the back that moves the reflector bowl up and down.
Does anyone know how to get these out?
Old May 13, 2005
dirtySAMURAI's Avatar
I log in from time to time
I'm gonna say that you have to pull on the reflector until either 1 of 2 things happens: 1) The reflector bowl comes out, or 2) The mounting tabs break and the reflector bowl comes out.
Old May 13, 2005
xam's Avatar
xam
snooty patooty partier
xam has a spectacular aura aboutxam has a spectacular aura aboutxam has a spectacular aura about
i am wondering y your doing this. something i can learn new everyday. i would say turn the screw counter clock wise till it doesnt come out anymore, then get the right tool (i dont know what its called), the screw looks like a *****. long shaft fot he screw and a ball end for the adjustments. u need the tool that will pull the side clips holding that ball end open, and pull the screw out. thats what i remember from my nissan.
Old May 13, 2005
he's doing it for his retrofit.
Old May 13, 2005
xam's Avatar
xam
koo thats what i thought too.
Old May 13, 2005
Boggie1688's Avatar
Diamond Member
Its cool...I finally got it....you gotta back out the adjustment screw until the refector reachest its full height. You have to keep on applying pressure and push the reflector up, then when its at the heighest point use a screw driver to push the tabs in. The hold the reflector in place, and push the tab and everything connected to it inward while u screw clock wise. This will pull the tab away from the reflector, when you get the tab all the way in...just push the reflector down push the tabs in on the other 2 mounting points and it just slides out nicely. Took me 2 hours to figure that out.
USCGBM
Aug 12, 2015 04:22 PM
carid
Aug 4, 2015 08:56 AM
Nikipedia
Jul 28, 2015 10:50 PM
Green02civic
Jul 27, 2015 10:48 PM
2001CIVICLX
Nov 6, 2002 09:34 AM
