wiring oem fogs to come on with parking lights
Old Jan 20, 2005
shmik1's Avatar
just what it says...
has anyone setup their oem fogs to come on with parking lights instead of headlights, or anyone know how it can be done?
Old Jan 20, 2005
gh0st's Avatar
TAQUITOS!!!!
http://handaaccessories.com/civext01.html
havne' tyou asked this before?...i'm guessing just follow the instructions in the link, just scroll down to fog lights and pick your year.
honda installed my fogs and they come on with with the parking lights as long as the button is pushed in.
Old Jan 20, 2005
mini-nsx's Avatar
mini-nsx is an unknown quantity at this point
Interesting, are you sure?
Our `04 doesnt...
Old Jan 20, 2005
No they don't. If the dealer follows the install instructions, they only come on with the headlights. The kit itself has a relay that only sends power when headlights are on.
Old Jan 20, 2005
dirtySAMURAI's Avatar
I log in from time to time
I followed the honda instructions and my fogs come on with the parking lights so long as the button for fogs is pushed in. I think it may have something to do with the relay and plugs that are used.
Old Jan 21, 2005
mini-nsx's Avatar
So how about you share what you did different?
Old Jan 21, 2005
This is a big secret I guess. Every single thread about this has zero info, just people saying they've done it. What's the big deal? I'm just too lazy but I could easily figure it out by studying the wire diagrams. I'm sure it's a simple tap the the parking light wire from somewhere. Impulse did it too but he won't say how.
Old Jan 21, 2005
No, I did not tap any wires. I just used the wiring and plugs that came with my kit (it's not OEM Honda fogs). That might be the thing - I bought OEM STYLE foglights, so they are set to turn on with the parking lights.
All I know is that my fogs will turn on/off when the parking lights, driving lights, and/or high beams are on.
Old Jan 21, 2005
mini-nsx's Avatar
There has to be a way, I had it done in my RSX-S. However, I did it AFTER someone else figured it out and gave good instructions...
I agree, these threads go no where, I've been trying to figure it out for almost a year now...
If you still have your instructions around, maybe someone would be willing to compare them to OEM honda instructions...
Old Jan 21, 2005
The instructions that were included with the foglights were not thorough. I had to use the Honda instructions in order to install them (I think that's why my wiring was too short...). The wiring of the fogs goes under the steering column into the fuse box. What I know from that is that the power to fogs is actuated by the headlight switch.
Old Feb 4, 2005
02civic_rida's Avatar
I luv what he siad, he starts off like he's gonna help you but then he contributes to not helping anyone... lol
not hating, just thought it was kinda funny i guess but yea, im trying to find it out as well, i have it right now to where i can turn it off even if the car is off, so it really doesnt matter if the car is on lights on or off.... but im trying to figure it out. when someone does find it out and is willing to let us know... TELL US!!
Old Feb 4, 2005
gh0st's Avatar
TAQUITOS!!!!
i'm guessing the dealer i took it to followed the directions i linked you too... i don't know why they'd put instructions on how to install it with the headlights only but then bother to make it so they come on with the parking lights also.
Old Feb 4, 2005
mini-nsx's Avatar
http://forums.clubrsx.com/showthread...hlight=fog+fix
The link above will take you to some VERY good instructions on how to do this mod to an RSX. I did this over 3 years ago, the mod never failed, never gave me any BS. Except the brights indicator didnt work, but I got use to it, but then got fed up and figured that out myself later...
Anyway, if someone would like to see if the wiring is the same on the civic's, this migh be a good guide to start. I could be wrong, but I bet they are similar if not the same. I just havent had time to get in there and look...
Hope that helps...
Old Feb 4, 2005
streetglower's Avatar
just tap the power wire into the parking light wire. Shouldnt be that hard.
Old Feb 4, 2005
mini-nsx's Avatar
Right.., why didnt everyone else think of that
Old Feb 4, 2005
That's a terrible thing to do...hook two 55w bulbs off a tiny wire designed to run a parking light.
Old Feb 5, 2005
you can run extra wiring with it if you do it the correct way. I have done it before on my older car, works fine. Or you can just use a switch with the kit.
AzNmiKex215
Nov 29, 2001 08:02 PM
NukeSilo
Nov 20, 2001 05:17 PM
klam
Nov 16, 2001 03:36 PM
wawacito
Nov 5, 2001 03:32 PM
NukeSilo
Nov 4, 2001 09:37 PM
