The recent LED lights thread gave me an idea.
Old Dec 9, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
I was thinking of attaching an led or two inside the doors near the door handle so the light glows through the slits for the handle hinge. And hooking it up so the leds light up when my dome light is lit. That way when I go to unlock my doors the handle lights up. Any comments on this idea?
Old Dec 9, 2004
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
goodluck, sounds hard
Injen
Old Dec 9, 2004
injencivic's Avatar
http://www.7thgencivic.com/memberrid...cat/fav/page/1
heres one outside, thanks to impulse
Injen
Old Dec 9, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
hehehe
you stole my stolen idea...
someone else has it done on a nhb sedan.. looks hella nice.. if i stop being lazy and figure out what im doing.. im doin it..
Old Dec 9, 2004
wonderz's Avatar
wonderz is on a distinguished road
Injen
ohh, thanks injen for the pic.. so that's what he's talking about.. haha
i guess i can do it and then wire it to my exterior streetglow switch.
(i said exterior 'cause i am planning to put 2 extra side tubes for the interior too which will have another switch. )
Old Dec 9, 2004
ImPulse's Avatar
I think its nice... ONLY
when the interior center dome light is on... Dont keep it on whenever you have your headlights on... I can kind of see it as a luxury addition
I think White or Yellow would be the only colors that would look best (or color of car?)
Old Dec 9, 2004
wonderz's Avatar
what if someone needs to use the dome light while driving.. then it lights up and there happens to be a cop near by and wants to pull you over
Old Dec 9, 2004
tbaleno's Avatar
I thought it was an original idea. I guess I was a little to late with the idea to be original. Still it looks cool though.
The cop will probably find it cool I think driving with the dome light on is the same as driving with these glowing. I was thinking of possible hooking a relay up so it only works when the dome light is on AND the gear is in park on my car (automatic). Didn't know if the effort was needed though.
So that guy used neons huh?
Old Dec 9, 2004
wonderz's Avatar
haha, i am paranoid when it comes to messing with the "important" stock wires.. like transmission wires, ecu wires, etc... but i am fine if i use my own wires
Old Dec 9, 2004
ImPulse's Avatar
well, whenever im driving at night i never use the "big" dome part... Just the ones that you push... You could always make a switch but, that would be dumb
Old Dec 10, 2004
chicohonda02's Avatar
Since 2002 Baby!
ya hook it up to a switch for crusing times. I like that idea, for show too. Nice
Old Dec 10, 2004
TeLLy's Avatar
Yes, it's an Acura EL
You could just hook up a relay to run off the door sensors, could you not? Then a 470Ohm resistor in the power wire, and a 5mm hole drilled in that little panel you pull off when you wanna take off the door panel - done and done.
The only issue I see here is running that wire from the door sensor or its terminal points in the kick panel - you have to get it INTO the door, and as all the people who have amped their front speakers know, this can be a real PITA.
Old Dec 10, 2004
wonderz's Avatar
haha, for some reason after i thought about it for a while, it doesn't look that good anymore... damn, i change my mind so easily.
Old Dec 12, 2004
againifall's Avatar
Go Team Venture!
oddly i was thinkin about it more.. and went out and looked at my car today.. and did some more thinkin... and i dont like the idea anymore either.. its cool and all.. but... not my style..
Old Dec 15, 2004
dirtySAMURAI's Avatar
I log in from time to time
How about have it turn on with your blinkers? Like you're using your right turn signal and you have your door handle light up amber with the blinkers?
Old Dec 15, 2004
tbaleno's Avatar
Thats an interesting idea. I wonder if thats illegal though.
Old Dec 15, 2004
againifall's Avatar
Go Team Venture!
shouldnt be any legal problems.. its basicly the same thing as the blinker lights on peoples side mirrors..
ChristinaVHH
May 10, 2015 03:51 PM
pincookie1
May 4, 2015 12:22 PM
tylerginevan
Apr 27, 2015 12:29 PM
blackbullet
Dec 1, 2001 03:44 PM
mwwhonda
Nov 30, 2001 08:44 PM
