HID problem
Old Nov 27, 2004
Raul's Avatar
Raul is an unknown quantity at this point
HID problem
One of my HID bulbs doesn't completely turn on. When I turn my headlights on it seems like is gonna turn on for a second but doesn't.
I swapped the bulbs (passenger to driver and viceversa) and the faulty bulb now does the same on the other side, so basically the ballast should be fine.
Anybody knows how this can be fixed?
Old Nov 27, 2004
New hid bulb? Maybe one too many bumbs in the road broke it.
Old Nov 29, 2004
Raul's Avatar
well of course if there is no way of fixing this then I will buy a new bulb, but I am just asking if there is a way to fix it, maybe by installing something
Old Nov 29, 2004
wonderz's Avatar
wonderz is on a distinguished road
if its the bulb, don't think you can fix it...
Old Nov 29, 2004
chrisleecool's Avatar
^^^ yea
but samething happened to me when I was installing my HIDs, the problem was the "connection between cables, one of the cable wasn't completely connected to each other" check on that if u haven't
Old Nov 29, 2004
ImPulse's Avatar
Road bumps wouldnt do that because HID bulbs dont have filamint? SP (damn im tired) (something only halogen bulbs have).
anyways, since you checked both sides, you realized that it is the bulb, not the ballasts, so, you obviously need new bulbs
Old Dec 3, 2004
yurcov's Avatar
New Member
yurcov is an unknown quantity at this point
actually it is so difficult to give some advice, `cuz would be better to know what du use, brand, bulb type etc. But as some1 mention above, check all connections, try to illuminate possible failure and make sure that everything connected to the right end.
Rogelio Rey
May 24, 2015 08:30 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
Professional
Jan 6, 2002 08:27 PM
0100010
Jan 6, 2002 12:54 AM
