relays?
Prowlin' with a Purpose
relays?
well im planning on hooking up some relays to serve my purpose...
i just put some neon rings in my headlights, and trying to figure out what amp rating i should get the relays...
heres what i wanna do, i know how to wire them up, just not what rating i should get, tap the parking light so the rings are on when a switch and the parking lights are on, easy... then put another relay in so that when the headlights are on, the rings shut off, easy.. but what amp rating should i use? i plan on running both set of rings on the same circuit, so only 2 relays would be required
and no they arent blue.. they are purple.. cause i used a UV cold cathode kit
so when im reading this relay...
4 and 3 is going to be an uninterruped power source on a switch such as a light circuit correct?
now that means position 5 is always on no matter what, until a current goes through 3-4?
or is it the other one?
Originally Posted by doubledeuce2k2
position 5 will be on when current goes btwn 3 and 4. otherwise, position 2 will be on.
that squiggly line will pull the switch towards it when current goes through it
the relay will have 5 hot, until a current goes throught 3,4 then 2 will go hot...
u sure? cause i got other ppl saying its the other one thats normally closed..
i think the diagram shows the default position
after reading this im sure of one thing....
i have no idea what im doing.. someone come help me.. unless its raining im doing this saturday..
jammer48
Oct 4, 2018 10:04 PM
h4ldol
Apr 24, 2017 08:16 PM
pilebuck13
Sep 21, 2015 10:45 PM
Juanb24
Sep 15, 2015 12:39 AM
