8000K HID kit
Old Feb 5, 2004
winchris's Avatar
winchris is an unknown quantity at this point
8000K HID kit
I just got my HID kits not long ago.. but when I try to install it, it would light up.???
My HID kits are only for low beam, I think I connected everything right... but I am wondering how come it won't light up?
Old Feb 5, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
you have to see if all your connection is rite I understand what ur going thro mine was like that too but i later found that some of my connection was not rite, recheck and you should be fine/
Old Feb 5, 2004
winchris's Avatar
I am not sure how am I suppose to connect it?
coz I only have the low beam HID rite?
and the connector for the power has three wires, black, red and white. and the bulbs only have two wires, black and red.. so I am not sure how can I do it?
Old Feb 5, 2004
Kloverz's Avatar
ok dont you have the instruction on you 3 wires rite 1st wires pos 2nd wire neg and the 3rd wired Ground if im rite but make sure you check which wire is rite. but thats how mine is 3 wires 1 pos-2neg-3grnd
Old Feb 5, 2004
winchris's Avatar
yes... but that's only for the connector... my bulbs only have two wires, red and black... so I am not sure where the white wire from the connector goes?
Old Feb 5, 2004
Kloverz's Avatar
what do you have oem headlights or aftermarket? but dont the instrution show you where the White wire goes?
Old Feb 5, 2004
winchris's Avatar
oem headlights... but the bulbs are HID.
Old Feb 5, 2004
Kloverz's Avatar
im sorry man i tried but i just cant picture it in my head how urs look as for my its projector so its easy pos and neg then I ground the other wire, Some one will answer you.
Old Feb 5, 2004
winchris's Avatar
thanks man... I will try to ask others... thanks a lot ...
Old Feb 5, 2004
Voiceofid's Avatar
End Bringer
what kind of kit is it?
if the kit connects the positive and ground directly to the battery, then the white wire could be for the headlight on off relay
tell us what kit, and pics if possible
and most hid kits tells you to test the setup before attaching it to your body
Old Feb 6, 2004
winchris's Avatar
maybe the problem is that I didn't change the fuse, coz I read sth about this problem on other sites and ppl are saying the problem maybe is the fuse... do u guys think so?
Old Feb 6, 2004
Voiceofid's Avatar
End Bringer
i have 2 hid kits, and niether required me to put in a bigger fuse
Old Feb 8, 2004
winchris's Avatar
do u think I need a relay kit?
Old Feb 8, 2004
winchris's Avatar
Old Feb 8, 2004
Voiceofid's Avatar
End Bringer
my catz kit used the factory bulb connections, so it didn't need one
my xenodepot kit came with the relay all wired up and ready to go
take a pic of the stuff you got, it'll be easier to figure out than sitting here describing it
UltraHDGames
Jun 8, 2016 05:16 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
TheRiddicles
Sep 21, 2015 01:28 AM
