Quick Question
Old Dec 27, 2003
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
Quick Question
ok.. so what part exactly makes a dual beam kit dual? is it the bulb or the ballast? or both? still debating on doing retro or just say f it and put in dual H4's.... i know impulse and id will convince me on retro, but i'm curious anyways.. lol
Old Dec 27, 2003
DogstyleEX's Avatar
also along these lines, let's say i get the mccullough dual h4, then i decide to get a different bulb (dual capable?) will that be feasible?
Old Dec 28, 2003
ImPulse's Avatar
lol... Man, The reason for an H4 bulb being "dual" is because of the shield and filament inside the bulb...
If u decide to get a McCulloch H4 aftermarket kit, and WHEN the bulb DOES break... You will need to get ANOTHER H4 HID bulb... Or, New harness.
Since aftermarket kits are now illegal, It will be very hard for you to find a Bi-H4 bulb... A lot of them are only low beam bulbs.
cough... Aftermarket HID Kits suck... cough
Wait... What does OEM mean? Oh.. Wait... Original Equipment Manufacturer? Hmm... Origional... or Aftermarket... >=]
Old Dec 28, 2003
Voiceofid's Avatar
End Bringer
oem bixenon dual beam's highbeam is created with a actuator that moves the cut-off playe on the projector
aftermarket dual beam uses a actuator that moves a shield foward and backwards below the bulb
Old Dec 28, 2003
ImPulse's Avatar
H4 HID:
An H4 is constructed to use the upper portion of the reflector only when low beam filament is on. An internal shield in the H4 bulb will reflect light going downwords towards the upper portion. When you turn high beams on, low beam filament will turn off and high beam filament lights up. It is mounted a little away from the low beam filament, so the beam will hit the road further ahead.
So what happens if you slam an HID bulb in there, correctly mounted in the focal point?
Very simply, the entire reflector will be used and even the orange light that normally emits from the lower portion of the HID bulb will be visible on the road. In other words total useless light. By having the HID return wire of the bulb turned down and using an appropiate shield made in stainless steel or aluminum should correct most of it.
Many kits out there makes you give up high beam. Some people claim that HID will give you the extra light, so high beam becomes unneccsary. This is not true.
http://faq.auto.light.tripod.com/
Tedverseti
Apr 23, 2020 01:45 PM
civic98?
Aug 13, 2015 01:32 AM
Strycker
Aug 2, 2015 08:40 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
