DIY: blue glow needles!
Old May 23, 2004
  #391
mos_skeeto's Avatar
mos_skeeto is an unknown quantity at this point
Middle of the wire where the plastic is? Sorry im a noob. So confused
Old May 23, 2004
  #392
Yeah, the plastic is just covering the actual wire. You want to tap the wire to get power.
Old May 23, 2004
  #393
mos_skeeto's Avatar
Thanks.
Went to radio shack and got everything but forgot resistors. Went back and all the locations don't carry them any more. Stupid canadian welfare radio shacks
Old May 29, 2004
  #394
Woodster's Avatar
Woodster is an unknown quantity at this point
Ive got a 6th gen civic, im doin my gauges and center console deal amber/orange. At the moment ive taken out the gauge cluster, got some spray paint, and painted the bulbs that had the condoms(great name) on them orange, let em dry overnight, then flip em over and am doing the other side. It looks great, just make sure, if 7th gen civics are the same, that you cover the connectors, otherwise its a ***** to get back in. Also, I ordered the amber lights for the center console from honda, part # 79609-S02-A01 if anybody is interested.
Old May 30, 2004
  #395
Post some pics of the results?
Old May 30, 2004
  #396
Woodster's Avatar
Me? if so definately, i painted the bulbs with orange instaead of red and im letting them dry until tonight, ill post it up when i get it taken. Also, once i go to the honda dealer in a few weeks and put the console lights in, ill post some pics for ya.
Old May 30, 2004
  #397
Woodster's Avatar
Argh, im havin serious problems here. I got the bulbs back in, looks nice, but i tried prying out the needles to clean the red off of them and 2 of them snapped off, i mean the metal part snapped like halfway down, good thing it was only the fuel and the hot/cold gauges. Alsoooo, my rpm and mph gauges dont seem to be responding, before they would like say i was idling at 3k and going 40mph just sitting their, dnt know why. Gosh i feel like such a dumbass. If i can just fix the rpm and mph ill be fine for the time being. What to doooo.
Old May 30, 2004
  #398
When I pulled mine, I put them back the same way and all of them worked fine. For the broken ones, maybe you can glue them on once you're done for good.
Old May 30, 2004
  #399
Woodster's Avatar
when you pulled them did they come all the way out including the metal rod. Some of mine did and some of mine didnt, im not sure how im going to glue the 2 broken ones b/c the proken metal rod is down i nthe little plastic white deal and i cant get to it, maybe put some glue on the end of the broken piece and set it in their? Gosh i feel so freakin stupid.
Old May 30, 2004
  #400
Maybe. I don't know how different they are. My needles have a hollow plastic ring that you slide over a metal rod. The rod is part of the cluster circuitry. So if there's enough space to glue them together, it may work. The needles are light and don't need much force to turn. Use some of that sealant glue that's clear and dries hard in 24hrs.
Old May 30, 2004
  #401
Woodster's Avatar
Ive decided im just going to buy a Si gauge off of ebay, cause its never going to be as vibrant as i want it if i just paint the bulbs. SO yea, ill lay down like 200 on a gauge cluster, im so pissed at myself.
Old Jun 2, 2004
  #402
ELaudio's Avatar
ELaudio is an unknown quantity at this point
I thought I'd give an update on my gauges, since I haven't posted in several weeks. I started my project in March of this year and what can I say - it's been quite the experience! Definitely a learning curve involved in figuring out the best way to evenly illuminate my cluster and needles. I'm currently about to start my last and hopefully final modification.
If you followed this thread back in March, my original plan was to illuminate every number and character with its own LEDs. I did just that, and as TeLLy can attest to, my gauges are really bright. They're ridiculously bright in fact, so much so that I usually drive with the dimmer switch cranked all the way down. I originally planned on illuminating the RPM red-zone with white LEDs, and the red lines "ticks" on the temp and gas gauges with white LEDs as well. As it turns out, it was almost impossible to prevent white light from escaping into the blue-zone of my gauges. So, I decided to make the numbers 7 and 8 on my tach, along with the RPM red zone, light up with RED leds. Same goes for the "H" on the temp gauge and the "E" on the fuel gauge.
I'd like to say I'll put up a DIY, but I think that would be pretty impractical. I've taken lots of in-process pictures with my digital camera, but overall, I've probably spent in excess of 80 hours working on my cluster, the ventilation controls and other switches. So, the DIY would be like 30 pages long and I don't have much time to do that. What I can do, though, is put up all my pics and offer assistance with questions.
I received my last order of LEDs (the red ones I needed) from lsdiodes.com (I HIGHLY RECOMMEND THIS SITE!) earlier this week. I'm hoping to finish things up this weekend, but I'm also installing oil pressure and oil temperature gauges so that may take more of my time...
PICS to follow...
Old Jun 2, 2004
  #403
Glad to hear, and I can't wait for pics. I think you're the first to do an EL and go through that much detail.
Old Jun 4, 2004
  #404
FALKEN's Avatar
Civicforums Junkie
need help...
how do i remove the board from the plastic housing for the power-window panel??
ive got it all apart, but i cant seem to get the board out due to the power-window lock button...
does this button pop off or something??
(if it makes a difference, its a 4-door)
Old Jun 4, 2004
  #405
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
Falken, the plastic top of the window lock button can come off by pulling it up. I'm not sure if there's much difference between the coupe and 4-door, so you might want ot ask gearbox on this one as I can only speak for the coupes. You may want to go to Honda and for a parts diagram that shows all screws and pieces that come off.
Originally Posted by FALKEN
need help...
Old Jun 4, 2004
  #406
FALKEN's Avatar
Civicforums Junkie
i pulled on that button top (pretty hard), but it wouldnt budge
gearbox : can you shed some light on this??
Old Jun 4, 2004
  #407
FALKEN's Avatar
Civicforums Junkie
**NEVERMIND***
i got the button off
Old Jun 6, 2004
  #408
Woodster's Avatar
man, illuminating every single number with its own LED, thats gotta be unreal man, but its gonna look awesome in the end. Ive got my a/c unit and the whole center console out at the moment and am awaiting next thursday when i go to the honda dealer and pick up my new bulbs for them. Once i find a Si cluster on ebay im gonna ****** it up b/c they seem to be really really rare.
Old Jun 7, 2004
  #409
92civic's Avatar
92civic is an unknown quantity at this point
is ther a way to take of the needles without breaking them? i have a 92 civic...tnx in advance
Old Jun 7, 2004
  #410
If they're the same as the newer civics, you should be able to pull them out. Just grab from the bottom with your fingers and pull straight up. I don't know what might happen with the calibration or anything. But usually if you take them off and put em back the same way, it should be fine.
Old Jun 7, 2004
  #411
92civic's Avatar
damn...i tried that....its stuck on ther pretty tight...im afraid theyll crack in hakf
Old Jun 7, 2004
  #412
92civic's Avatar
hmm ok...i broke 1....
not too happy bout that
ne other suggestions?
Old Jun 7, 2004
  #413
Is it possible to glue it back on? Usually the needle has a plastic tube that goes over a metal rod sticking out of the cluster. I can't say for sure because I don't know the older design.
Old Jun 7, 2004
  #414
92civic's Avatar
i broke the metal part rite in half....the other half is stuck in the plastic
Old Jun 7, 2004
  #415
If there's room, you can try and glue it together. Or maybe some sticky tape so long as it doesn't wobble. The needles don't weigh that much. I would put some cement glue around it and then tape on top of the needle to hold it in the center. In 24hrs, it should be solid.
Old Jun 8, 2004
  #416
AlienX's Avatar
AlienX will become famous soon enough
dude, when I was trying to pull my needles off I had the exact same problem. It felt as if I was going to break everything, including the needles + the metal. It requires a tight grip under the needle and a pressing motion. It will hurt your fingers alot but it worked for me.
Gear has removed his soo many times that they are more loose then a goose.
Old Jun 9, 2004
  #417
FALKEN's Avatar
Civicforums Junkie
UPDATE AND NEW DIY--POWER WINDOW SWITCH (Blue LED)
**This was by far the hardest part of this entire DIY. I got so frustrated trying to do this. You need alot of patience to get it right. The pics are just to see how stuff comes apart. Most of it is either held on by tabs, clips, or screws. The door panel does not need to come off to get the window assembly out. You will also need very thin magnet wire to set everything up. Thicker wire won't fit between the two halves of the assembly. One of the hard parts is to make sure the driver window switch works mechanically after putting the LED inside. The LED must be shaved down alot for it to fit. I just cut out the factory LED that was in there.
Now here is the wiring part. I found out which two wires have to be tapped for ground and power. The ground on the plug is the black wire that my finger is pointing to.
The positive wire is the yellow one where my finger is pointing. I stripped a small section of each thick wire and then wrapped magnet wire around it to make the connection. Just be sure and tape everything up.
Just don't forget the 680ohm resistor before the LED to reduce the power coming in. I forgot and had to do everything all over again. You can imagine how pissed I was.
im not sure why you had to do all of this...
it wasnt that hard for me to do
(i just desoldered the stock LED and then soldered in the new one)
Old Jun 9, 2004
  #418
Blue leds use a different resistor than stock for the LED to last a long time. I bet yours will just burn out faster. Oh and now my wiring got messed again. I had to reach in and push stuff to make it light up again. lousy electronics
Old Jun 15, 2004
  #419
ToX's Avatar
ToX
ToX is an unknown quantity at this point
Why can't I see the pictures????
Old Jun 15, 2004
  #420
Pics are all there. If your connection is slow, you might not be able to see them all. Try looking in my ride gallery for some.
