pics of REALLY noisy rear brake - looks OK but....?
Rep Power: 0 pics of REALLY noisy rear brake - looks OK but....?
When this '05 turns left, there's a clunk-clunk-clunk every wheel revolution from the rear right. That makes sense, as the weight shifts to the right.
My mechanic said 'noisy backing plate' from just hearing my description.
But upon opening it up, I see nothing out of the ordinary. Anything here look off? I see no rub marks.
It DOES clunk pretty loud when turning left
your input is appreciated - thanks
Re: pics of REALLY noisy rear brake - looks OK but....?
Shoes look fine to me, none look thin enough to worry about.
Look at the outermost circumference of the drum in the last pic, there is a rough but somewhat shiny area that is usually covered in rust.....It may have been making contact with the backing plate?
Hammer? There are threaded holes in the drum so you can use a bolt to push it off the hub instead of beating it.
Rep Power: 0 Re: pics of REALLY noisy rear brake - looks OK but....?
I replaced pads & rotors up front and also bought new shoes but when I saw that, I decided to just return the shoes.
If you heard the clunk clunk clunk at each wheel revolution, you'd agree that a single one of those clunks would result in more shiny metal if a little contact was the source of the noise. It runs almost quiet in a straight line but gets noisy when that right corner is under load (turning left)
To heck with it. I'm bringing it to my mechanic since we've procrastinated on getting the timing belt done since I bought it for her in April.
I'll record the sound and also what my mechanic does for it, in case this ends-up being useful for someone else out here.
Thanks Ezone
Good eyes! I'd never beat on it. If a few little taps doesn't break it loose, I'd use a bolt. Oddly, I it popped-off by hand, without any tapping at all.
Thanks Ezone
how many miles??
maybe change the hub! IMO brakes dont go click click on a turn
sway bar parts might need a look at!
brake hardware, wheel cylinder, and the rest should be changed so you dont have to think about the brakes again for a long time! i get drums & rotors on ebay under $20 ea
and no I dont support the "Parts Cannon" thingy cause daddy's little girl needs a safe car!!
There's NO reason I can think of for a rear wheel to make such a racket so you may be on to something.
It only has 115K kms, or 71K miles. It's been driven 5000kms since we bought it in April and what started as a click click click as the wheel turned, has degenerated into a clunk clunk clunk.
When I had the drum off, I stared at it, trying to imagine what the heck could cause such a racket, given that there's no obvious huge contact / wear going on.
It's my little girl's car so it's not going anywhere until it's been checked-out by someone way smarter than me.
thanks
thanks
It makes the clunking sound with each wheel revolution, when turning left / shifting weight towards the right side.
Can a sway bar make a noise that coincides with the wheel completing a revolution?
However: when we first bought it in April, we swapped-out rear way bar bushings (lower), since one had completely broken.
I should have recorded the sound so you could hear the racket.
It started-off as a click click (I posted about it and you guys suggested it was a CV joint at the time link) and even that was too loud to be a a rock in the tire.
Now, another 2000 miles later, it's a much louder clunk clunk that you can perceptibly feel. It's definitely not a stone.
None of us can hear the noise yet either LOL.
I'm sure nobody realized your noise was coming from the REAR of the car in the previous thread, you never made any reference to such.
Seems like most noise complaints originate in the front, so that's where all our guesses went.
Does the noise occur without applying the brakes, or do you have to push the brake to hear it?
Hell, swap the tires and drums side to side and see what happens?
MS Paint FTW"
Here I tried to mark the shiny spots in the edge of the drum in red, it looks like the areas have been rubbing against something (the backing plate??) to wear the rust off and make shiny contact points:
MS Paint FTW"
The sound is audible (barely) when driving straight. It starts REALLY clunking when driving around a left-hand turn, regardless of brakes being used or not.
I've heard a grinding drum many times - awful sound. Can't be confused with the clunk-clunk-clunk I'm hearing now
I noticed the wear you highlighted too but immediately dismissed it because a single one of those 'clunks' would result in more wear than is seen in the pic. Plus, that wear is dispersed around the drum - The car clunks at one distinct point, each wheel revolution.
And I assume it's relevant that the sound has gotten much worse than when I first reported it in April.
Anyway, I'm resigning myself from this until tomorrow. When my mechanic test drives it, I'll be in the back seat beside the offending wheel to record the event. I'll post the video/sound, as well as the official diagnosis.
More as it comes - thanks guys
so your making this turn and it makes a noise... could it be your ABS kicking in trying to correct traction and theirs a problem with the wheel cylinder or something ABS related?
hoping ezone can answer this one!
The car does not have traction control or vehicle stability control, so IMO the driver would have to be braking in order for ABS to do anything at all.
OP has not said if the noise only happens during braking though.
ezone was right
Rust buildup. It was so bloody LOUD that I couldn't imagine that little bit of rub evident in the pictures to be the cause of the racket.
My mechanic cleaned it up and all is well. Thanks guys
7thgensurvivor
38
08-29-2015 11:50 AM
MamaBear2015
06-11-2015 07:33 PM
