Notices
Brake pedal has to be increasingly pushed in.
Old 10-07-2012
civic_guy_386's Avatar
civic_guy_386 will become famous soon enoughcivic_guy_386 will become famous soon enough
Coming to a stop, I depress the brake pedal and the car stops.
But after a few seconds the car slowly begins rolling again unless I push the pedal down further.
I have to keep doing this to stay stopped and the brake pedal feels like it's nearing the end of it's travel.
The brake fluid level looks ok.
Any idea what the problem might be?
Old 10-07-2012
Stock 99's Avatar
Re: Brake pedal has to be increasingly pushed in.
classic failing master cylinder symptom.
Old 10-07-2012
Thanks - just watched a vid on master cylinder replacement.
Looks complicated but do-able (by a newbie like me).
Old 10-07-2012
Stock 99's Avatar
Yeah, changing a master cylinder is easy. It's like 6 bolts, a Civicnoobie could do it.
It's bleeding the hydraulic lines that's a PITA. If you do decide to DIY hydraulic lines it's well worth it to get a brake bleeder.
Old 10-08-2012
You gonna stand in front of that?
Old 10-08-2012
rjones7755's Avatar
a Civicnoobie could do it..
You dick
Old 10-10-2012
Done.
Works like a charm.
Thanks for the advice.
Old 10-10-2012
Received 1,443 Likes on 1,198 Posts
congrats for the first big job
Old 10-10-2012
Stock 99's Avatar
right on! Glad you got it fixed.
Old 09-08-2013
marione43's Avatar
marione43 is an unknown quantity at this point
I had the same problem. but now I have no breaks whatsoever and I've done changed the master cylinder. and I've done the bench bleeding,gravity bleeding,and individual bleeding. and still no break pedal at all. can I please get some advice to fix my car.. thanks
Old 09-09-2013
any other parts that have been changed? ABS installed? could be calipers, or ABS, or lines, etc.
conspiracy90
06-07-2023 01:01 PM
WaryDriver
23
07-22-2015 07:18 PM
McLean
06-13-2015 10:32 AM
bsmiley
04-27-2015 01:27 PM
vtexcivic
12-17-2001 02:08 PM
Quick Reply: Brake pedal has to be increasingly pushed in.
