wiper won't turn off
Old 09-06-2010
rwbridal's Avatar
rwbridal is an unknown quantity at this point
I have a 1997 Civic and the wipers won't shut off. Replaced the wiper switch but no luck.
Old 12-05-2010
nsxvtec's Avatar
nsxvtec will become famous soon enough
Re: wiper won't turn off
Wiper motor assembly needs to be replaced. mechanism in wiper motor is defective.
Old 12-28-2011
happyboy2010's Avatar
happyboy2010 is an unknown quantity at this point
I have the same problem as of last night. My wipers will not turn off. How does one replace the Wiper Motor Assembly?
Old 12-28-2011
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner's Avatar
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
The windshield wiper motor on a 1998 Honda Civic sits underneath the hood of the car and is mounted to the firewall. The motor controls the function and movement of the windshield wipers. While there is no service life for the Civic's wiper motor, it will need to be replaced when the motor starts to hesitate. The motor looks like a small canister. Replacement motors can be purchased from most auto parts stores or directly from a Honda dealership.
Difficulty:Moderately EasyInstructions
Things You'll Need
  • Socket wrench
  • Socket set
Suggest Edits
  1.
    • 1 Open the hood and unplug the electrical connector from the wiper motor.
    • 2 Unbolt the two bolts that hold the wiper motor to the firewall.
    • 3 Pull the wiper motor off the linkage assembly.
    • 4 Slide the new wiper motor into place and secure it with the factory mounting bolts using a socket wrench.
    • 5 Reconnect the factory electrical connector to the wiper
Old 12-28-2011
Thanks Gunner. Is it advisable to replace the switch first, or replace the motor instead?
thanks again....
Old 12-28-2011
Gunner's Avatar
If it is the switch i would do that first..
.also check your connections make sure they are not crossed or shorted before you actually replace the motor or switch..
Old 12-28-2011
Okay thanks. I will try the switch first....
Old 12-28-2011
How can I tell if the switch is a problem or if the motor is the problem?
My wipers respond in all positions except the off position. I drove around for a while (with the wipers stuck in the on position of course, the first speed) and after some time the wiper gets stuck near the bottom position now and then. If I change to the next speed it will become unstuck. I just priced the switch and it was about $120 at Bridge auto parts. In any case I will look online to save $$.
Old 12-28-2011
lazlong's Avatar
There's only 3 things it could be- the switch, the motor, or a bad wire/connection. Do you have a multi-meter and know how to use it? If so, find MelJ and download the service manual from his sig and diagnose for a faulty wiper switch.
OEM switch is number 10: http://www.hondapartscheap.com/index...ATION%20SWITCH and takes about 10 minutes to replace.
OEM motor is number 5: http://www.hondapartscheap.com/index...IPER%20%281%29
I'd look for one at the salvage yard first or look here for nationwide salvage listings: http://www.car-part.com/
Old 12-28-2011
Thank you lazlong. I am getting there.....I appreciate all the help on this forum!
pratik05
05-15-2015 01:54 PM
autowill
05-15-2015 11:36 AM
shindrome
Exterior
05-05-2015 02:50 PM
SatinSilver2k1
12-23-2001 06:19 PM
Quick Reply: wiper won't turn off
