96-98 Civic Aftermarket Head Unit Install?
Old Dec 26, 2011
blackstang's Avatar
blackstang is an unknown quantity at this point
Hello,
How are you with 96-98 Civic's securing the aftermarket head unit to the dash. The 2 screws that held the original radio do not have matching holes on the aftermarket unit. Anyone using metal strapping or a custom bracket on the back of the aftermarket unit?
If you just pop the new stereo in without screwing it down, it would be very easy to steal.
Thanks.
Old Dec 28, 2011
Sirh22a99ek's Avatar
Sirh22a99ek is an unknown quantity at this point
Re: 96-98 Civic Aftermarket Head Unit Install?
Try a dash installation kit
Old Dec 29, 2011
SpdySylvrEX's Avatar
SpdySylvrEX will become famous soon enough
I never used the bolts to re-install my head unit. The aftermarket head unit should have come with a "sleeve" that goes on the outside of the actual unit. On that sleeve there should be tabs that you will bend out to prevent the head unit from being pulled out. This sleeve locks the head unit in.
http://www.installdr.com/InstallDocs...PDF/466013.pdf
Try that link page 10 shows the bending of the tabs. It also shows keeping the old head unit. But the main thing I was trying to show was the pic of the tabs being bent down.
Hope this helps...
mistermenphis22
Apr 3, 2016 08:06 AM
mugenca
Apr 16, 2015 12:15 AM
blacklud
Apr 13, 2015 06:15 PM
streetglower123
Apr 12, 2015 10:56 AM
pdxbiker
Nov 7, 2001 10:06 PM
