Adjustable Lower Control Arm
Rep Power: 0 Adjustable Lower Control Arm
So I took my 98 Honda Civic in for an alignment after replacing the shocks. I was told I need to install an adjustable lower control arm in the rear as the right-rear wheel camber is -2.1 degrees and can't be adjusted. I was quoted $200 parts and labor.
Looking for other, more knowledgeable, opinions on this. Is this something that's common? The Civic has 170K on it, so I don't doubt the LCA could be damaged, but why wouldn't replacing it with an OEM be the way to go? How difficult is it to replace the control arm?
This was a 'new' mechanic, and I'm not entirely trusting of his recommendation.
Thanks in advance!
Thanks in advance!
Rep Power: 0 Rear camber Kit - one side okay?
So after some research, it seems what I need is a rear camber kit. I don't know what the hell he was talking about with the adjustable lower control arm.
Next question, do I need to install one on each side, or is it okay to just install on the side that's having the camber issue? I was going to go with the Ingall's rubber (daily driver).
Received 1,442 Likes
Rep Power: 338 Re: Adjustable Lower Control Arm
i think mechanic was thinking on the front suspension that uses double wishbone.
by any chance, is your rear suspension sagging low?
camber changes with car height, maybe springs getting tired or dampers too weak (not sure wich dampers you put on, but that could be a factor.).
don't think you would need special camber adjustment in stock suspension unless something did change. problem is somewhere else and could come back to bite.
Rep Power: 0 Re: Adjustable Lower Control Arm
So, spec is from 0 degrees to -2.0 degree. Mine is -2.1 degrees. So although a full degree from 'optimum', it's only 0.1 degrees out of spec.
Is this really something to be concerned with? Nothing appears to be sagging, and I'd never have known there was an 'issue' if the alignment didn't tell me so. I'm guessing that the springs, with 170K on them, are just a tad weakened.
I'm thinking I'm going to leave it as is.
just be careful on low grip situations that makes the understeer more noticeable, otherwise should not be biggie
07-12-2015 11:54 AM
CivicsClass101
07-09-2015 11:14 AM
