cutting a/c belt and removing idler pulley bracket
Old 05-17-2012
v34563cv's Avatar
v34563cv is an unknown quantity at this point
hi,
i don't use a/c at all...in fact i don't even think mine works at all. So i've decided to cut the a/c belt off. also i was going to remove the idler pulley bracket because the a/c belt isn't there any more.
is it safe to remove the idler pulley bracket and continue to run your car.
i would think it would be safe as long as the a/c belt isn't there any more.
by the way i have an automatic d16y7 engine
Old 05-17-2012
Re: cutting a/c belt and removing idler pulley bracket
If all that is on that belt is the compressor and the idler/adjuster pulley (NOT the alternator), then you should be safe to chop it.
I probably wouldn't mess with the idler pulley at all, make sure it is tight so it can't fall off. But yes you can remove it if you want.
HTH
EdGasket
05-25-2015 01:06 PM
Flipg123
05-22-2015 10:43 PM
oqjoi
05-09-2015 10:31 PM
MN-02-CivicEx
28
05-02-2015 09:11 PM
1028CiViC
03-21-2002 11:29 AM
Quick Reply: cutting a/c belt and removing idler pulley bracket
