Possible Oil Leak...
Rep Power: 0 Possible Oil Leak...
Hey all you honda guys, this is my first honda, it is a beater. I bought it off of some kid for 1800 and according to him it has a new head gasket, a re-build auto transmission, new water pump, new timing belt, new plugs, etc.
I had it parked in my gfs garage the night i bought it, when i woke up in the morning I had a some puddle (size of a quarter) on the garage floor where it was parked. I'm pretty sure it is oil, don't think it was transmission fluid.
I had the car up on jack stands yesterday and changed the oil out and put mobil 1 in it, but i couldn't figure out where it was leaking from. The oil is running down from somewhere and collecting then dripping.
Any ideas of what it could be? I am hoping the block isn't cracked. I told the kid about it, and he said it never leaked as far as he knew.
BTW its a 97 civic with a d16y8 engine.
Re: Possible Oil Leak...
How well did you clean up after pulling the oil filter off? The runoff can drip for quite a while.
Whachya lookin at?
Rep Power: 289 Re: Possible Oil Leak...
Start with common places, like ezone said check for runoff and make sure your oil filter is sealed tightly. Also check that the oil plug is torqued correctly and the crush washer is in good shape. Clean the underside of the engine and monitor it daily and after drives to see if you can see signs of new oil, thats a good way to find a leak. Another possibility is your oil pan gasket. Take some pictures, over the net its a guessing game without at least a picture.
brags
46
01-07-2016 09:39 PM
emich
12-11-2015 12:20 PM
SidCivic
17
08-23-2015 03:14 AM
fafa1234
08-08-2015 06:42 PM
fecrni
08-08-2015 06:15 PM
