need tips on getting power from battery
Old May 31, 2003
wonderz's Avatar
wonderz is on a distinguished road
Question need tips on getting power from battery
can you guys tell me what's the best way to get power from the battery? I am thinking of tapping into that thick wire that comes right off the battery, but not sure if its the best way. TIA
Old May 31, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Either get a new battery clamp and re-wire that way, or take a wire and use a ring terminal and attach it to the bolt that tightens the + battery cables to the battery. Don't tap your OEM battery wires.
Old May 31, 2003
wonderz's Avatar
So if I need more wires to the battery, I can just tap into the one that I created with a ring terminal, right?
Old Jun 1, 2003
VNlilMAN's Avatar
The Standard One
what are you trying to power?
Old Jun 1, 2003
wonderz's Avatar
a relay for the headlights
btw, what's wrong with taping into oem battery wires?
Old Jun 1, 2003
WhiteRabbit's Avatar
a relay for the headlights, you cna grab power anywhere. including diretly at the battery.
we will usually pull it off the fusr box, one of the constant powers going in there, or we will put a ring terminal on teh small-*** 16 guage wire and yup, put that righ ton the battery terminal itself.
its messier ot do it to teh battery itself, but its supereasy. and jsut as reliable...
Old Jun 1, 2003
wonderz's Avatar
i want to pull it off the fuse box, how do i do that? mystic said not that mess with the oem battery wire going to the fuse box, so I don't know where I can tap the power from the fuse box...
Old Jun 1, 2003
Mystic3030's Avatar
You can tap in at the fuse box...I meant don't cut into the OEM wire and tap like that. I also thought you meant for an amplifier. I havent tapped the fuse box for our civics yet, so i'll let someone with more experience explain how to do that.
Old Jun 1, 2003
wonderz's Avatar
ok...can you guys tell me how exactly can i get power from the fuse box? thanks
Old Jun 1, 2003
youll have to look for the easiest way in there, ive never done fogs or sidemarkers or any other sort of work like that in a 7th gen civic to be honest, but i would imagine it works like any other car.
you look for any wire thats hooked to constant power fomr the battery, using a test light, once you find the hareness, and you cna grab power form there.
Black91civic
Jun 6, 2015 08:15 AM
HiImBrandon
Jun 1, 2015 07:34 AM
trellex
May 24, 2015 04:39 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
