need some help.
Old Jan 15, 2007
spoonEM's Avatar
omgwtfbbq mod.
need some help.
So I was re-wiring my radio and realized Im not getting constant power. Im getting switched power, but not constant. I took my MM and tested the switched at the harness that plugs into the factory harness, where I had switched, and no constant. So I unplugged the harness and checked the factory harness. Again, switched, but no constant. So unless I was checking the wrong plug, then Ive got a problem. Where should I check next?
Old Jan 15, 2007
spoonEM's Avatar
omgwtfbbq mod.
The grey box gets power with the key on, and no power with it off since its my switched power.
The black box has no power at all. Thats where the constant 12v is.
Old Jan 15, 2007
sl33pyriceboi's Avatar
check ur fuses. the #10 IS the constant power.....its suppose to be always on. trying taking ur MM again, and make sure u are touching the MM + head to the male pin of the plug...
Old Jan 15, 2007
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Check "Back up" Fuse in your hood fusebox (7.5)
Old Jan 15, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Underhood fusebox
Fuse #9
10A
Old Jan 16, 2007
spoonEM's Avatar
omgwtfbbq mod.
i know #10 is constant...thats what Im saying. that is the wire thats not getting power.
Originally Posted by christmaspie
Underhood fusebox
Fuse #9
10A
I checked the fuse already and its fine. I just went and double checked it...its still fine.
Im stumped. lol
Old Jan 16, 2007
The only junction on that wire between the fuse and the deck is in the underdash fuse box. I'm not sure how much fun it will be to track that connection down and check it out though. Here's some diagrams that might be useful. If you're spending too much time tracing it down you could just re-wire to the constant at the ignition harness with a fuse. (white wire, 40A)
The constant wire comes into the underdash fusebox @ pin 2 on the J plug. The J plug is number 12 in the J plug diagram. It is on the rear-facing side of the fusebox.
The wire leaves the underdash fusebox towards the radio @ pin 4 of the N plug. The N plug is number 9 in that diagram and faces the front of the vehicle.
Good luck!
File Type: pdf
File Type: pdf
Old Jan 16, 2007
spoonEM's Avatar
omgwtfbbq mod.
Good luck!
Got it. I think Im just going to do that since none of my fuses are popped. Thank you very much for your help and +1 for you. Im pretty confident in all electrical aspects of this car, I just got stumped on this one stupid wire. haha
Old Jan 16, 2007
spoonEM's Avatar
omgwtfbbq mod.
Damnit...I have to spread rep before giving it again. Ill rep you when i can rep again.
Old Jan 16, 2007
spoonEM's Avatar
omgwtfbbq mod.
So you think I should just tap into the #4 pin on #9 of the N plug diagram and just run that for the constant 12v source?
Old Jan 16, 2007
That might be the easiest thing to do. You could just grab power at the white wire @ the ignition harness and tap into N4 thru a fuse. However, if there is an open somewhere in that wire it won't work. Check continuity between that N4 in the fusebox and pin 10 at the deck harness. If there's continuity then I would tap it like you say.
Old Jan 16, 2007
spoonEM's Avatar
omgwtfbbq mod.
Cool, Ill check it out tonight when I get home. Thanks for the help.
ken4444
Sep 30, 2015 07:37 PM
juicetayne
Sep 30, 2015 11:02 AM
frank_kleng
Sep 29, 2015 10:55 PM
Islesfan
Sep 29, 2015 03:42 AM
C-Hamm
Sep 28, 2015 10:31 PM
