help with voltmeter install needed.
Old Dec 1, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
I just received my voltmeter and I'm putting it near the gauge cluster. Where can I find a dim wire (a wire that has 12V on it when the lights are on?) I don't want to pull the cluster. Is there one in the ignition harness or do I have to look elswhere?
Old Dec 1, 2004
MegaHurtz's Avatar
try looking on the steering column
Old Dec 2, 2004
Just pull the cluster. That's the easiest way, although with your hybrid I don't know if it's the same one. Or if you're lazy, tap the ignition power source like cig lighter plug and it will come on when the key is in.
Old Dec 2, 2004
MegaHurtz's Avatar
i think it would be very easy to do if you checked the steering column because of course the wire for the headlight switch will be in there, but then again it will be pre-relay so it might not be a good source. Get up in there with a DMM/test light and find out is the funnest way!
Old Dec 2, 2004
tbaleno's Avatar
humm. I've search a lot last night and can't seem to find wiring diagrams for our car or the cluster. Can anyone give me a link?
Old Dec 2, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
How about running above the pedals under the plastic panels to behind the radio, and tapping into the one for your HU. That would be easy....
Old Dec 2, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Red wire/black stripe is the illuminatin wire
red wire is the dimmer wire. On the bulb, hook up one end to the red/blk the other to the red. then the light will go on and dimm just like the dash
mine are like this, along with red condoms, they dim like the rest of the lights and look pretty close to the color
Old Dec 2, 2004
tbaleno's Avatar
Thanks I realy appreciate the help on this. A few more questions. The illumination wire is +12V when the lights are on correct? Also I plan on using a t-tap on the wiring harness of the radio and I'm wondering what gauge the wires generaly are for aftermarket wiring harnesses and if using a t-tap is okay.
My guage doesn't realy dim like the regular gauges it just basicly just dims when it gets 12V (its ment to hook up to the driving light/parking light wire) There is no gradation of dimming.
Old Dec 2, 2004
MegaHurtz's Avatar
should be 16-18awg and yes its +12v
Old Dec 2, 2004
WhiteRabbit's Avatar
theres also one of those wires going into your hazard switch in the dash if your gauge is closer to that part of the dash.
Old Dec 3, 2004
yche086's Avatar
yche086 is an unknown quantity at this point
Hey that radio looks COOL!! Any chance you telling us how you did that cover thing for it/where you bought it from?
Old Dec 3, 2004
tbaleno's Avatar
who me? If so then its just a piece of abs cut to fit the opening. I recessed an alpine unit that auto retracts. and vecroed the piece to it so when the radio opens and closes it takes the piece with it.
Old Dec 3, 2004
yche086's Avatar
Hmm, I gotta say it looks more impressive than it sounds
Old Dec 4, 2004
tbaleno's Avatar
Well, the guage is in. I hope I can get a digital camera for christmas so you can see how it looks guys. I'm sure someone will be wanting to by the cluster pod housing and will want to see how they look installed. I know I did. I could only find 1 picture of gauges mounted in one of these pods.
Thanks for all the help with color codes and stuff of the wires.
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
jzhartman
22
Jul 23, 2015 10:42 PM
EM_WON
Jul 22, 2015 06:49 PM
General 7th Gen
Jul 9, 2015 10:17 PM
