Eclipse Amp.
Old Apr 18, 2004
AlienX's Avatar
AlienX will become famous soon enough
Eclipse Amp.
Hi, I have an eclipse amp model 3242, its a 4 channel amp. Besides it specs I will get to the point.
When I power it up, the power LED goes green for a second then it turns off. I checked, and changed all the fuses but no go.
Does anyone have any ideas ?
Old Apr 18, 2004
AlienX's Avatar
ne1?
Old Apr 18, 2004
fonto's Avatar
The LA Clipper
Gound maybe? Make sure your grounds are tight on bare metal. Does you amp have a "protection" mode, and is a lit indicating it?
Old Apr 18, 2004
AlienX's Avatar
the ground is fine because I have another amp connected now to it ( rockford) and it works fine. It doesn't have a protection LED. I have unscrewed it to try to narrow it down to maybe a fried component, but i'm stumped.
Old Apr 18, 2004
fonto's Avatar
The LA Clipper
Do you have another amp that you can hook up to see if all the connections work with another amp?
Old Apr 18, 2004
AlienX's Avatar
yes, I have the rockford hooked up right now.
Old Apr 18, 2004
fonto's Avatar
The LA Clipper
Ok, try swithing them up and see if the Eclipse works on the RF wiring and visa-versa.
Old Apr 18, 2004
AlienX's Avatar
i had an RF laying around and I hooked it up yesterday and it works. I dont have 2 amps installed.. its just 1, and 1 set or wires...
I put a can of Co2 at the amp.. I"m gonna try it now to see if it might have been a short of some sort.
Old Apr 18, 2004
AlienX's Avatar
nope, did nothing...
I have a small 12v power supply at home. I powered up the amp, it stayed on longer then it did when hooked up to the car, BUT ! it drew soo much power that it melted the cables to the power supply...
Gsxtacy
Sep 12, 2015 01:09 AM
jamesbbh
Apr 28, 2002 04:18 PM
edy
Apr 24, 2002 03:24 PM
AlexLx
Apr 16, 2002 11:04 PM
fourkilos
Apr 13, 2002 06:55 PM
