09 Civic Wiring diagram for headlights
Old 04-30-2011
Grkkboy's Avatar
Grkkboy is an unknown quantity at this point
me and my friend need the wiring diagram so we know what to hookup the accessory led/halos wire to either parking lights or the daytimerunning or nightlights or ignition blah blah all help is appreciated
Old 04-30-2011
CraigW's Avatar
Re: 09 Civic Wiring diagram for headlights
Parking and Tail wire color = RED
Ignition... I can only think of ACC socket, not easy to get into bay though. If you need ignition I could check it for you.
DRL/High beams imo should be avoided if possible. The multiplex is in control of the headlights on the 8th gens, and theres the whole half brightness stuff using drl.
Old 04-30-2011
Grkkboy's Avatar
any pictures you could give?
Old 04-30-2011
CraigW's Avatar
Pix ?? for ignition switched source ??
The PDF version I have will not work with a pdf printer/creator.
I could create single sheet pdf files with the older ones (usually)
Old 05-21-2011
Grkkboy's Avatar
its fine just give me it
Old 05-21-2011
CraigW's Avatar
Give you what ??
Likely will have to print then scan.
Default_Slayer
Electrical DIY
12-04-2022 07:56 AM
usajags84
15
08-19-2015 03:12 AM
shaejb15
04-26-2015 07:44 PM
darwin-t
04-18-2015 09:29 PM
NukeSilo
11-04-2001 09:37 PM
Quick Reply: 09 Civic Wiring diagram for headlights
