radio upgrade fail - need advice
Rep Power: 0 radio upgrade fail - need advice
I Installed the following in my '09 GX to replace the factory original, but when I put the volume past 50% I get horrible bass distortion. I pulled the HU out of my volvo where it drove the stock volvo speakers just fine.
Do I need to be concerned with vibration or deadening? I'm inclined to think not, but I don't know. I've installed stereos before and have never had any problem like this. Any advice appreciated!!
I have the same problem in front as well as rear.
Since this is a GX I didn't want to bother with a heavy mod of the back deck to sink in speakers, so I went with the surface mount TSX-150's. ... but I mounted them to the plastic panel, not the steel beneath. But that doesn't sound like it's the problem.
I am thinking of putting in a sub and amp to cover the bass because the rest of the range is fine, but that seems overkill, it would be great if I could just get the equipment I have sounding better. ( wish I had tested it out before installed ) but putting this in the GX would be a bit of a challenge that I'm not sure I'm ready for.
FRONT: Pioneer TS-G1643R
Woofer Cone Material: Composite IMPP Cone
Surround: Cloth
Voice Coil Bobbin: Poly-Imide
Damper: Conex
Tweeter: 1-3/16" Balanced Dome Tweeter with Neodymium Magnet
Watts MAX. Music Power: 180 Watts
Watts Nominal Power Handling: 30 watts
Frequency Response: 30 Hz to 28 kHz
Sensitivity (1W/1m): 90 dB
Ohm Rating: 4
Mounting Depth: 1-5/8" (42 mm)
Cut-out Dimensions: 5" (128 mm)
REAR: Pioneer TSX-150
5-1/4" Paper Woofer
1-1/8" Ceramic Horn Midrange
3/4" Ceramic Horn Tweeter
Bass-Reflex Cabinet
60 Watts Max Music Power (20 Watts Nominal)
Frequency Response: 75 - 20,000Hz
Sensitivity: 89dB (1W/1M)
4 Ohm Rated
Head Unit: JVC KD-HDR1
RMS Power Output 20 watts
Peak Output 50 watts
RMS Power Bandwidth 40-20kHz
Preamp Outputs 6-channel
Sub Preamp Outputs Yes
Surround: Cloth
Damper: Conex
Ohm Rating: 4
5-1/4" Paper Woofer
Bass-Reflex Cabinet
4 Ohm Rated
Dave1984
07-22-2015 06:10 PM
