drl
Old 07-23-2014
junbug's Avatar
junbug is an unknown quantity at this point
drl
Does anyone know where the drl module located in a 2007 honda civic lx
Old 07-23-2014
Re: drl
There isn't any standalone control unit for them. The DRL control is built into the multiplex system.
Why would you ask this? Got a problem with the DRLs?
Old 07-27-2014
junbug's Avatar
Re: drl
the drl light is on
Old 07-27-2014
junbug's Avatar
Re: drl
my drl light is on its not the fuse or bulbs
Old 07-27-2014
Re: drl
So does that mean your DRLs DO work, and the high beams DO work?
Most I have encountered with the DRL warning light on have been either a problem with one or both high-beam bulbs/sockets/wiring, or I've seen it on when the high beams have been converted to HID or LED without using the correct adapters.
So if both your high beams DO work correctly and the DRLs work correctly, then I'd say
to begin, check all fuses in both fuse boxes,
Then check for any powertrain fault codes, F-CAN and communication loss codes.
Then I'd scan it for any fault codes in the body systems.
(Google-fu feels strong!)
HOLY COW I think I stumbled upon a gold mine of troubleshooting info:
Warning: This looks like a HUGE list of pages, MICU manual troubleshooting and code info starts around the 4th page
http://www.scribd.com/doc/82769529/2007-Honda-Civic
mac25
08-21-2015 11:14 PM
gkako
10-26-2008 03:16 PM
jta
Lighting
17
07-31-2005 11:41 AM
FurBall
08-29-2002 02:57 AM
Quick Reply: drl
