2006 EX Wiper Motor Cover Plate Replacement
Old 10-20-2010
CLR06EX's Avatar
CLR06EX is an unknown quantity at this point
Anyone know where I can locate these diagrams? I need them so that I can replace the wiper motor cover plate on my civic. The dealership quoted me $545 to do it and I quoted him George Jefferson.
Thanks
Old 10-21-2010
lazlong's Avatar
Re: 2006 EX Wiper Motor Cover Plate Replacement
Plate? I'm assuming you mean the cowl (the cover over the wiper motor between the hood and windshield).
To remove the cowl:
Tools required- 10mm socket, flathead screwdriver, trim tool, extra body pins like the kind in the cowl (you'll probably break some getting them out)
1. Remove windshield side trim. They are held on with metal snaps and just pry off. *Use a trim tool so you don't ruin anything. If you can't use a trim tool use the thinnest flathead you have. Make sure to put tape on the paint whether you use a trim tool or flathead so you don't ruin it.
2. Remove the nut covers on the wiper arms.
3. Remove the wiper arm nuts then remove the arms. *Make sure to mark the arms before you take them off, if your one tooth off they won't swing right.
4. Open the hood and remove the hood seal on the front top edge of the cowl. *Be careful, they can rip easy sometimes.
5. Remove side seals.
6. Take your flathead and pry up all the body pins on the cowl. Once you take out the body pins there should be nothing holding on the cowl.
cheapest trim tools around: http://www.harborfreight.com/4-piece...set-38386.html
btw- body pins are little plastic pins that look like this (as you see, I ruined mine getting it out. lol):
Jigee
05-09-2015 11:18 AM
shindrome
Exterior
05-05-2015 02:50 PM
MN-02-CivicEx
28
05-02-2015 09:11 PM
mievil
04-28-2015 11:02 PM
thesushiboy
04-12-2015 02:54 AM
Quick Reply: 2006 EX Wiper Motor Cover Plate Replacement
