What is this piece called?
Rep Power: 167 What is this piece called?
It's a rubber strip on the exterior of the window door to prevent water from entering the door panel, and I guess prevent damage to the door when the window is rolled all the way down.
I highlighted it in red.
2000 Civic Hatchback DX
What's the name, can it be replaced, how and where can I get a new one? lol Thanks!
Super Moderator
Re: What is this piece called?
WEATHERSTRIP, FR. DOOR (INNER)
You can buy it here:
http://www.hondaautomotiveparts.com/...NT+DOOR+LINING
It's part 4
Looks like you can replace it!
It's part 4
Received 1,149 Likes
Rep Power: 485 Re: What is this piece called?
If you're looking for a replacement because the rubberized coating is cracking, exposing the metal backing, then a cheaper alternative is to buya can of plastidip, strip it completely, tape it off, then spray down a layer or two of plastidip.
Rep Power: 167 Re: What is this piece called?
BTW, I took a look at the door and that #4 piece is found on the INSIDE of the door. I'm looking for the actual rubber piece that's found on the direct opposite of the window on the EXTERIOR side.
Found it!!
Part number #1 and #3.
http://www.hondaautomotiveparts.com/...tcgry5=MOLDING
Hmm, maybe I'll suffer a little while longer, kind of expensive.
Problem is when I wash my car in winter, my latch/lock and tumbler freeze solid!
Climbing through the hatch FTL.
Received 1,443 Likes
Rep Power: 338 Re: What is this piece called?
Grease the latch and linkages real good.
You will never stop all the water from coming in.
fvckbg
10-20-2016 07:37 PM
09-27-2015 11:33 AM
Touge
09-01-2015 11:25 PM
