Sponsored by:
Sponsored by: DashLynx
White smoke coming out of AC vents
Old 08-30-2016
tempid's Avatar
tempid is an unknown quantity at this point
I turn on the AC when I start the car and start driving, no smoke.
I get on the highway, drive few miles maintaining 70 mph, turn the AC off for a few minutes and turn it back on, I see white smoke coming out of the vents. There is no smell to it. It goes away in about a minute.
What could be the issue? Heating core? Coolant leaking? something else?
tempid is offline
Old 08-30-2016
Re: White smoke coming out of AC vents
It's not smoke.
It's water vapor.
Normal. Nothing wrong.
You just got it into a situation where you can see water vapor.
Same water vapor that makes up a cloud.
ezone is offline
Old 09-01-2016
lowlife9's Avatar
once,white smoke came out of my acuras vents after the head gasket blew out. i don't remember if it had a smell though.
lowlife9 is offline
Old 09-02-2016
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
If there is no coolant smell, then it must not be a failed heater core leaking coolant.
NDNV is offline
Old 09-02-2016
Originally Posted by ezone
It's not smoke.
It's water vapor.
A thought: You're more likely to witness this vapor phenomenon when using fresh air instead of recirculate.
ezone is offline
Old 09-03-2016
tempid's Avatar
Thanks for the responses. This never happened in the 11 years I owned this car though.
The "recirculate" mode is always on when I turn on the AC. There's no smell and the smoke/vapor dissipates in about a minute. But it comes back when I turn the AC off for a few minutes and turn it back on. I haven't noticed this issue when I'm driving on the local roads where the speed limits are low.
tempid is offline
Old 09-03-2016
Still normal.
ezone is offline
Old 09-11-2016
sf170089's Avatar
sf170089 is an unknown quantity at this point
I have an 01 LX. The first time this happened to me, I totally freaked out. I actually did not see much on-line about it either. It used to happen a lot. I never took the time to troubleshoot the exact conditions. But, it seems to have gone away and hasn't happened in years. I had actually forgotten about it until seeing your thread. I am glad it is considered "normal" :-).
sf170089 is offline
Johhny
ECU Fried
12-16-2015 01:24 PM
mgcivicdriver
Engine start problems
16
12-10-2015 11:58 PM
sruger
11-15-2015 02:52 PM
chilling_pete
11-05-2015 10:05 PM
99BoostedSi
11-03-2015 06:32 PM
Quick Reply: White smoke coming out of AC vents
