drilled and slotted break disc????? tips???help!!!????
Rep Power: 0 drilled and slotted break disc????? tips???help!!!????
thinking of doing something to make the car stop quicker and shorter, and at same time to get them too cool down faster. any tips or input? if i upgrade the disc to i have to get new calipers and break pads too or how does it work?
Re: drilled and slotted break disc????? tips???help!!!????
if your replacing rotors then yes, its recommended to replace the pads also at the same time....i would never put old pads on new rotors....slotted or drilled rotors will not help you stop quicker, they just cool faster
Rep Power: 0 Re: drilled and slotted break disc????? tips???help!!!????
I used to have a 98 eclipse and It had drilled and slotted break discs, and it used to stop on a dime in dry, and in wet they very rearly locked up, it also had nice new tires. And obviously new break pads but I mean like I do they got to be special break pads and if I stick with same size break disc then the calipers should fit right? Also about rear breaks drums how do I go about that?
your eclipse is not a honda civic....stop comparing apples to oranges....the stopping power had nothing to do with drilled or slotted rotors, all that does is help with the cooling of the rotor, it has nothing to do with stopping power....as i said previously, slotted or drilled rotors will not make your car stop better or faster
Busy Speeding!!
1 Post
Rep Power: 170 Re: drilled and slotted break disc????? tips???help!!!????
More contact will help your car stop faster. A 10" slotted rotor has less surface area than a 10" OEM rotor. Upgrade your brake lines to stainless steel if you want performance. Or get a big brake kit with a disc swap for the rear
Rep Power: 232 Re: drilled and slotted break disc????? tips???help!!!????
yup nothing can compare to 4 weel disc brakes but if thats not an option then oem blanks with hawk hps pads is your best bet.
1 Post
Rep Power: 328 Re: drilled and slotted break disc????? tips???help!!!????
omg. another slotted/drilled rotor thread...
first of all, tires stop your car. not rotors and calipers.
second of all, getting drilled/slot will worse the amount of distance required to stop on your car (in general).
1 Post
read it.
you are prob wondering why kenny said slotted/drilled and negligible in performance for our cars.
the original intent of drilled rotors (the holes) was the allow excess gas to be sucked into the vains of the rotors (inside of the rotor) to prevent gas build up between the rotor surface and pad. HOWEVER, pad technology has gone a very long way and the technology for it has exponentially improved. gas is no longer a problem.
drilled rotors also serve as a cooling purpose. it draws air into the veins of the rotor and pushes it out (like many computer fans). however, to do this efficiently, you need directional veined rotors. there is NO aftermarket stock sized rotor that makes directional vein rotors. our 10" rotors are too small for manufactures to give a crap because no one really "races" our rotors to even be considered. most "track/race" civics will have a big brake kit on there.
directional vented vain vs straight vained (what we have) rotors:
now, slotted rotors. those are the little slits you see on rotors. their purpose is to act as a razor blade and clean the surface of the pad with every swipe to allow a clean pad contact with the rotor. HOWEVER, this will EAT UP YOUR PADS very very quickly (compared to say a blank rotor)
application to our cars:
why do we advise NOT to get them for our cars? a few reasons.
1. when you drill/slot the rotors, you significantly lose surface area of your rotor. that means less surface area for your pad to come in contact with your rotor. this means less friction, less braking power, and a loss in braking performance.
so why do all the higher end cars have them? because they run 15" rotors and we run 10." they can throw some drills/slots in there and not sacrifice surface area.
2. properly drilled/slotted/veined rotors are meant to take and cool high heat...ie racing applications. if you drive on the streets and do occasional spirited driving, you will rarely push your rotors to its limits. and if you ARE serious about racing/autox, then your stock rotor is extremely insufficient and you need to think of investing in a big brake kit.
3. drilling/slotting the rotors weakens the structure. period. there is no argument in it. its basic physics. when you look at the cars that have proper drilled/slots, you will notice that the thickness of their rotor is MUCH thicker than ours.
google it, you'll find plenty of failed rotors that were drilled.
and this isn't exclusive to our little rotors. There have been guys with the IS-F that have cracked their oem rotors on the track. google and you shall see.
now, for street applications for your civic, if you want to go with slotted/drilled rotors, then thats fine. chances are you will not push those rotors to their limits and if you got a decent brand, you'll be ok.
and if you want them simply for looks, no one here is to tell you otherwise because its your car, your taste. hope you have learned something and hope i have cleared some confusion concerning drilled slots.
Makes since, I wouldn't get that for looks, it's a daily driver so I want it to be safer before I go faster. Look is just the bonus
Received 1,443 Likes
Rep Power: 338 Re: drilled and slotted break disc????? tips???help!!!????
most recent one, if you wondering
https://www.civicforums.com/forums/4...t-awesome.html
and if you really serious, better read first:
https://www.civicforums.com/forums/4...elled-out.html
https://www.civicforums.com/forums/4...1-01-05-a.html
and no, it's not an easy undertaking. one member had his troubles when attempting one conversion. and he is no slouch, but the differences caused a lot of trouble to him.
if you just saying for saying, do not recommend trying.
but most of all, as sl33py put it so well, what stops cars are tires, not brakes. if you lock then tires, no matter what locking power brakes have. if you ask me back what is the best tire? i will simply reply the best for the circumstances. (extreme performance tires in snow does not sound right, correct?)
BTW, why are you lol'ing?
1 Post
If your peddle gets soft under braking then its time to flush your brake system and put new fluid in there.
And it you want a stiffer/firmer (less spongy feel), get stainless steal brake lines
1 Post
If you can lock your tires out at almost any speed, then your rotors/pads are not the weak point. Get better tires.
If you car doesn't feel like its slowing down fast enough, then it's probably your pads are crappy and don't create enough friction to slow the car.
I checked the rotors are not smooth, extremely ruff very wavy surface, and what I ment was I had a few times where I'm going down hill and it's steep about half a mile long, and I have to be on the breaks they basically faded on me and just went super soft, and smelly, after it cooled down it became fine again, so I guess real question is how much faster do the drilled and slottered break rotors actually cool down, and is it worth it?
The pedal is still same stiffness but the way the car reacts to the amount of pressure applied don't match, and come a point when I'm pushing hardest and all the way and the car is barely dropping speed, and when it does stop they almost glow. So I ment the breaks get soft not the pedal
you might need to use engine brake or swap to DOT4 fluid.
you loosing brakes because they are actually doing their job. and heating the fluid...
1 Post
1 Post
Rep Power: 176 Re: drilled and slotted break disc????? tips???help!!!????
It's "BRAKES", not breaks, pet peeve. If you are fading stock brakes under stockish use, two things come to mind. Either your pads are junky, or your braking technique isn't very good... Learn to drive a semi or big truck and the first thing you learn is how to brake properly. Stab the brakes hard to get to your "set speed", then let off of them completely until the upper set speed, then repeat as needed. Doesn't matter if you have 10 inch or 20 inch brakes if you ride them they will heat up. Also, use engine braking it is your friend. If you have a manual transmission, in general if you climb a hill in a specific gear descend the other side in 1 gear lower. If you have an auto it is a bit out of you hands....
1 Post
lol...****... i ride my brakes in purpose in the mornings to heat them up. gawd damn hawk HP+ pads dont work properly unless they're hot.
based on his comments and stuff, i simply thought it would easier to tell him to switch to DOT 4 than teaching him how to drive through internet...
I can concur that slotted rotors do not noticeably improve braking in our cars. My car came with them from the previous owner. When they wore out, I replaced them with regular cheap rotors and noticed no difference at all.
What will improve braking a lot more is a good set of performance shocks, springs and sticky tires. SS brake lines and a properly bled system will make the pedal feel crisp and tight, and you will feel as if the car has stronger brakes.
1 Post
Wider, yes. Bigger nope, unless they are alot lighter. More rolling inertia to stop. Came from a truck background. If you put big tires and wheels on you better do some upgrades in the brakes too or you will rearend someone.... The gains would be from bigger brakes to go along with the 5-lug....
Whachya lookin at?
Rep Power: 289 Re: drilled and slotted break disc????? tips???help!!!????
RSX type "S" :
vs. RSX Base:
Huge upgrade. Your going from a 10" rotor to 11.8". These swaps can be seen on Kijiji for as little as 300 dollars. It is a big job though, and you need new rims+tires. Still cheaper than a BBK.
vs. RSX Base:
7th Gen Civic DIY Enthusiast!
Rep Power: 161 Re: drilled and slotted break disc????? tips???help!!!????
Yeah, still way more expensive than just running stock with little or no performance improvement on braking.
