Sponsored by:
Sponsored by: DashLynx
2003 Civic Coupe please help with diagnosis
Old 04-30-2011
03Civicuser's Avatar
03Civicuser is an unknown quantity at this point
Hi there, i have been reading up on the posts but can't confirm what the noise i'm hearing actually is.. I am getting a very loud rumbling (not sure how to really properly describe the noise) from the r.f. It sounds like a very scalloped tire noise but even though the tires looked great, i've changed over to summer tires and that isn't the cause. It doesn't happen at slow speeds but anything over 35- 40Kph it begins and gets very loud. I don't seem to have any slack in the wheel but as I was switching tires, noticed the hub area is quite hot, much more than the left. Caliper if free, pads show proper wear. Axle boot isn't torn and no clicking noise when jacked up and turning wheel by hand.. Does this sound like a wheel bearing to you and if so if this a garage project? alignment necessary, etc.. approximate cost? Oh and I forgot to mention, when turning to the left as an example to take the load off of the right wheel the noise drastically subsides.
Thanks in advance for all the help!!
03Civicuser is offline
Old 04-30-2011
CraigW's Avatar
Re: 2003 Civic Coupe please help with diagnosis
Wheel Bearing (can't say which side)
My mechanic said it was easy to spot.
CraigW is offline
Old 04-30-2011
Electronics Guru
Alpheus's Avatar
Alpheus should not be trustedAlpheus should not be trusted
You described classic symptoms of a bad right front wheel bearing. They must be pressed out and pressed back in...
Alpheus is offline
Old 04-30-2011
sl33pyriceboi's Avatar
a wheel bearing replacement isnt exactly a DIY at home type of thing unless you have the proper tools (press/press adaptors, hub extractor...etc) and it will also cost you a LOT of ur time AND FRUSTRATION. trust me, i did it and i know.
next time, i will just take it to a shop.
best thing is for you to buy a wheel bearing and take it to a shop and have them charge you for labor only.
sl33pyriceboi is offline
Old 04-30-2011
Live for the Twisties
MindBomber's Avatar
You could just pull the knuckle and take that to a shop, that's not to hard.
MindBomber is offline
Old 05-01-2011
lazlong's Avatar
I agree, bearings are a bitch. I have a table top press (6 ton) and still take them to a shop.
lazlong is offline
Old 05-01-2011
Ok, Great!! thanks for all the info.. will the car require an alignment afterwards and any idea what I should be looking at for labor? also is there a better brand of bearing than another? should I get OEM?
Old 05-01-2011
lazlong's Avatar
Yes, you'll need an alignment. If you take it to the mech for the whole thing $200-300. If you take the knuckle off maybe $50-100. Just go with OEM: http://www.hondapartscheap.com/southbay/jsp/home.jsp (just an example, there are others)
lazlong is offline
Poopies
04-20-2017 11:36 PM
miatabro
07-17-2015 12:12 PM
usajags84
05-10-2015 08:11 AM
Ian SFBA
Interior DIY
04-25-2015 02:25 PM
CapYoda
11-11-2001 05:17 PM
Quick Reply: 2003 Civic Coupe please help with diagnosis
