02 Civic LX - Weird Manual Transmission Problem
Rep Power: 0 02 Civic LX - Weird Manual Transmission Problem
Hello! Firstly, thanks to everyone who reads this and gives any input!!!
I just bought an 02 Civic 5-speed... the car runs great, with one exception... when shifting from one gear to another, it feels like something is blocking the path to completely put it in that gear. There's usually a plastic-like creak when I try. That being said, if I move the shifter towards the middle of the shift sequence (ie, when going from 1st to 2nd, if I move the shifter to the right towards 5th, then into 2nd), it shifts just fine. There is no grinding or gear scraping or anything like that... just the path is blocked unless I move off the path first. Does my description make sense?
Anyone have any idea what might be causing this?
Thanks so much!!!!
Thanks so much!!!!
Received 1,450 Likes
Rep Power: 339 Re: 02 Civic LX - Weird Manual Transmission Problem
go to a transmission store and have them check your shifter. adjust if necessary, replace if something broken
CarStuff
12-06-2020 12:52 PM
tylerginevan
04-27-2015 12:29 PM
C6GrandSport
04-25-2015 09:41 PM
SSMatey
04-13-2015 06:09 PM
