I used non-honda power steering fluid? Am I screwed even if I get it changed?
Rep Power: 0 I used non-honda power steering fluid? Am I screwed even if I get it changed?
So, I was frustrated that after my alternator was replaced I noticed my power steering fluid was leaking. Of course I didn't read the label clearly, and I used a brand that said "not recommended", which i noticed after driving the car home, which was about 5 miles. If I take it 5 miles back to the garage in the morning, am I already boned? Should I be telling them to go ahead and replace the pump or something like that?
Rep Power: 232 Re: I used non-honda power steering fluid? Am I screwed even if I get it changed?
you should be fine its only been in there for a short period of time your good. just get it replaced or do it yourself its fairly simple.
Rep Power: 0 Re: I used non-honda power steering fluid? Am I screwed even if I get it changed?
Thanks for the reply, and I'll be taking it first thing tomorrow to get it changed (also to find the source of the leak).
drain and fill, and you're golden. Anyone really know why it says honda fluid only i'm just curious, i know it says no atf also
Rep Power: 788 Re: I used non-honda power steering fluid? Am I screwed even if I get it changed?
honda fluid uses special additives for their ps system. same happened to our accord. parents opted for $1 generic fluid instead of $2.50 honda fluid, the whole pump started leaking. luckily a few drain and refills later with the honda fluid and everything was fine again. i wiped off the old fluid leaking and it hasnt come back.
Pistol grip pump in my lap at all times
mattdoc
03-14-2017 12:10 PM
moorebl
08-29-2015 08:39 PM
