honda 2009 coolant problem
Rep Power: 0 honda 2009 coolant problem
I was checking the coolant on my civic 2009 and I recognized that it is empty, is it normal for the coolant to be empty in the morning? and should I add coolant or check it cause I only driven it for 6000 Miles??
Re: honda 2009 coolant problem
Make sure you have some present when the engine is at operating temp.
My 2010 is at a very low level when cold. and lower than it was when at temp. Could be due to the overall temp drop ?? but i'm keeping a close eye on it.
Rep Power: 0 Re: honda 2009 coolant problem
When cold, you should be at the low mark, once its up to operating temp you should be somewhere closer to the full mark. Add antifreeze when the engine is cold to the low mark, then in a week or so, check it again when its cold and see if you've lost any, if you have, then you have a leak.
1 Post
Rep Power: 328 Re: honda 2009 coolant problem
which "tank" are u looking at?
because that "tank" you are prob looking at is the overflow resivor....and that is there JUST for the coolant to overflow to incase it gets too hot.
the only way to "know" ur coolant is low is the open the coolant cap and look if its topped off.
The only way for there not to be coolant up to the neck when you take the radiator cap is off would be if theres no coolant in the overflow.
In other words READ THE FRIGGEN OWNERS MANUAL PEOPLE! If you dont know how to check coolant levels, the owner manual tells you how to do it the proper (and easier) way. Its designed to be user friendly for those who dont know as much about cars. Theres no reason to pop the cap off the radiator unless you wanna check the coolant for proper mix or allow for faster draining of the system.
Rep Power: 787 Re: honda 2009 coolant problem
i like to keep mine at max when cold just in case. never had it spill over as there is still alot of room in there. there is a simple solution to all this and that is add more cooant. if it gets lost again without spilling, you have a serious problem.
Received 1,443 Likes
Rep Power: 338 Re: honda 1998 coolant problem
Don't desperately post anywhere you want, some stuff are really different from a 8th gen to a 6th gen.
AC on? have them check your heater core.
Rep Power: 338 Re: honda 2009 coolant problem
if not that (purposefully i posted in separate reply, note that) check in here
https://www.civicforums.com/forums/3...reference.html
Xuhme
21
08-07-2023 03:40 PM
thana
06-15-2020 07:05 PM
edgenet
05-02-2015 08:00 PM
jessicakaybby
04-20-2015 12:11 PM
Bartkat
20
02-19-2002 01:29 PM
