Can a d16 be quick
Rep Power: 0 Can a d16 be quick
I have a 2001 civic d16 hatch and was wondering if these motors have any potential to be quick or should I just get a motor swap
Re: Can a d16 be quick
yes this is true but using all theat money to build the d16 up will be almost the same if you swap and have barely any mods possibly even less if you know the right places to look for the swap or you have a friend but i have a d16z6 and with less powerful engines like this the first things you must do are air/fuel ratio this will have great increases then turbo/supercarge or w.e u want to do ur call ont hat one but im building my z6 up and ill post on how it goes gradually as i put more into it
Rep Power: 0 Re: Can a d16 be quick
Depends on what you're using it for. In a straight line, no. Around a corner, yes, if you make suspension and handling your first priority.
I've got a CRX running an unmodified D16 with exhaust, cold air intake, race coilovers and sway bars. The engine has 278k original miles and burns oil so bad I have to use 20-50 and still put in a quart every 2-3 weeks...but I still kill at Autocross!
My last race in 2009 was prettymuch the worst race I've ever run, but I still beat the majority of the new civics and half of the WRXs that ran that day.
Received 1,444 Likes
Rep Power: 338 Re: Can a d16 be quick
front dinamic camber gains: zero!!! wargh!
ricer_em2
05-11-2016 08:09 PM
